borth
#1 Posted : Sunday, October 21, 2012 9:01:56 AM(UTC)
borth
Hello, This is an old refrigeratior/freezer, but everything else works great. water just started dripping from bottom of freezer door. at first it was a very slow leak but leak is getting worse. dispenser and ice maker work fine. exposed tubing going into door looks to be in good shape so must be a crack in tubing inside freezer door. is it a major repair to replace tubing or can it even be replaced? can I disconnect water going to dispenser but still keep water going to ice maker so it will work?
thanks for your help,
Brad
rickgburton
#2 Posted : Sunday, October 21, 2012 12:45:09 PM(UTC)
rickgburton
Groups: Expert
Disconnect the water line connector and wire connector by the lower door hinge. Remove the upper freezer door hinge. Lift the door off and lay it on a flat surface. Remove the screws behind the door seal then lift the liner and door seal off or slide it over to access the water line. Use 1/4" line.
