centurionballer
#1 Posted : Thursday, November 20, 2008 10:29:38 AM(UTC)
centurionballer
my washer spills water it washes fine but when its in one of its cycles it just spills alot of water. from the top i am not sure if it has something to do with the the water pressure.
libertyappl
#2 Posted : Thursday, November 20, 2008 10:34:13 AM(UTC)
libertyappl
It overflows in one cycle? Need to know which cycle, wash or rinse.
Nat
kayakcrzy
#3 Posted : Thursday, November 20, 2008 5:23:35 PM(UTC)
kayakcrzy
Replace the pressure switch, or commonly called the water level switch. Tom ApplianceEducator.com
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 9/21/2020 9:46:26 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer leaks water while filling tub (Washer Repair)
by 2WHIRLPOOLSCLW 5/26/2013 4:57:28 PM(UTC)
Washer leaks water into tub continuously (Washer Repair)
by jray66cj 3/8/2012 5:47:01 PM(UTC)
washer leaks water into basket when not in use (Washer Repair)
by anne stromberg 7/2/2011 5:14:35 AM(UTC)
during spin washer leaks water from under nealth (Washer Repair)
by 21jam12 2/3/2010 6:03:43 AM(UTC)
washer leaks water out bottom (Washer Repair)
by jag11727 5/9/2009 7:36:08 AM(UTC)
dishwasher leaks water occasionally (Dishwasher Repair)
by jukenut 4/26/2009 6:40:48 PM(UTC)
washer leaks water (Washer Repair)
by puttputt1953 10/19/2008 8:18:14 PM(UTC)
Washer Leaks Water Into Tub After Cycle (Washer Repair)
by zinnco 7/29/2008 7:21:02 AM(UTC)
by watson-1 2/27/2008 7:12:57 AM(UTC)
