elvenezolanito
#1 Posted : Tuesday, November 18, 2008 5:30:58 AM(UTC)
elvenezolanito
My Kenmore He 3 dryer was working fine till i moved apartments, the apartment i moved had the 4 connection cable instead of the 3 i change it on the dryer but i think i connected wrong when i turn the dryer on the braker sitch turn off and the dryer quit working, i tried looking for a sensor or a fuse on the dryer trying to fix the issue i also corrected the cable connection on the dryer but i think i burned something in there what should i do to find out what the issue is and corrected?, Thank you..
Kenmore HE3t noise at beginning of wash cycle (Washer Repair)
by Brenda McAlpine 7/31/2019 10:27:42 AM(UTC)
Kenmore HE3 dryer - no heat (Dryer Repair)
by tdalton 10/2/2017 1:20:19 PM(UTC)
kenmore he3 elite washer water temperature control (Washer Repair)
by E!iteH#3 7/24/2016 12:49:19 PM(UTC)
Kenmore HE3 rear drum support or spyder (Washer Repair)
by Faranks 5/18/2015 8:35:00 AM(UTC)
Kenmore HE3 washer - drum not rotating (Washer Repair)
by Garageguy 2/14/2015 1:45:42 PM(UTC)
Kenmore HE3t F2 error message (Washer Repair)
by MovingMountains 11/2/2014 6:04:18 AM(UTC)
Kenmore HE3 Washer Vibration (Garbage Disposer Repair)
by SarahStrain 9/21/2013 9:18:09 AM(UTC)
Kenmore HE3 - won't drain (Washer Repair)
by fms1974 12/15/2012 2:19:18 PM(UTC)
kenmore he3t, error code f28 (Washer Repair)
by bleonard 11/19/2012 11:15:17 AM(UTC)
Kenmore HE3 Dryer starts then stops (Dryer Repair)
by nowhere 1/13/2012 8:32:59 PM(UTC)
Kenmore HE3T F1 error (Washer Repair)
by kkoennecke 1/2/2012 3:59:25 PM(UTC)
Kenmore He3 Elite E1 Code (Dryer Repair)
by 1007 12/5/2011 4:49:26 AM(UTC)
baffle is loose - Kenmore HE3 Front Load Washer (Washer Repair)
by tripdip 6/8/2011 10:16:07 AM(UTC)
Kenmore HE3 Front Loader is filling with water when machine is OFF and not activated (Washer Repair)
by dat2disc 5/1/2011 6:10:15 AM(UTC)
Kenmore he3 smoking? (Dryer Repair)
by jfoynes 10/5/2010 6:35:18 AM(UTC)
