devildog
#1 Posted : 16 years ago
devildog
When i turn the dryer on you can see the flame come on and start to feel the heat then it goes off
magician59
#2 Posted : 16 years ago
magician59
First thing to do is check for clogged vent.
devildog
#3 Posted : 16 years ago
devildog
I had the vent to outside off while I was running the dryer
DerbyDad03
#4 Posted : 16 years ago
DerbyDad03
Having the outside vent off doesn't mean the internal ductwork isn't clogged. There is usually a duct that runs from the top back wall of the dryer to the bottom opening where the external venting attaches.
devildog
#5 Posted : 16 years ago
devildog
i took thecover off the vent cleaned it throughly. started the dryer up flame came onthenshut off again. still the same problem
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 9 months ago
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 11 months ago
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag about a year ago
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam about a year ago
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 about a year ago
No heat when assembled (Dryer Repair)
by Guest about a year ago
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2 years ago
No heat, (Dryer Repair)
by tseibring 2 years ago
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 2 years ago
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 3 years ago
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 3 years ago
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 3 years ago
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 3 years ago
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
