devildog
#1 Posted : Monday, November 17, 2008 5:23:35 AM(UTC)
devildog
When i turn the dryer on you can see the flame come on and start to feel the heat then it goes off
magician59
#2 Posted : Monday, November 17, 2008 5:28:48 AM(UTC)
magician59
First thing to do is check for clogged vent.
devildog
#3 Posted : Monday, November 17, 2008 7:16:39 AM(UTC)
devildog
I had the vent to outside off while I was running the dryer
DerbyDad03
#4 Posted : Monday, November 17, 2008 7:42:04 AM(UTC)
DerbyDad03
Having the outside vent off doesn't mean the internal ductwork isn't clogged. There is usually a duct that runs from the top back wall of the dryer to the bottom opening where the external venting attaches.
devildog
#5 Posted : Friday, November 21, 2008 5:19:00 AM(UTC)
devildog
i took thecover off the vent cleaned it throughly. started the dryer up flame came onthenshut off again. still the same problem
Guest (5)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
