I have a whirlpool calypso that is leaking water all over the floor. the water appears to be pouring from a plastic sleeve in the back. I cannot find the model # anywhere on the machine. I am not sure what to do. Any help will be appreciated
Hi Michelle The complete instructions how to diagnose and repair the Calypso washer you can find in the repair manual. The model number of the washer is under the lid. Good luck. Gene.
If the water is coming out the overflow tube. then your pump is plugged.
