jammaker
#1 Posted : Wednesday, May 11, 2011 7:59:33 AM(UTC)
jammaker
I have an electric dryer I can't diagonize the problem. It runs but doesn't heat. Heater checks ok with 11 ohms. Thermal fuse is ok. Thermistor has 11.3 ohms. Thermal cutoff is ok. When I run it there is 115V from each side of heater to ground BUT from side to side there is 0V instead of 230V. Looks like it is getting power to only one side. Can someone help?
#2 Posted : Friday, May 13, 2011 2:00:57 AM(UTC)
Replacement parts for WHIRLPOOL GEW9250PW1 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the tech sheet
Your thermistor is way too low. It should be up around 11,000 ohms not 11 ohms. Be sure to unplug it when measuring it. Lower resistance is higher temperature so perhaps the control board thinks that the dryer is already very hot so does not turn the heater on.
If the above checks out OK.
Check across Heater Return to Heater +V, if you see 240 volts there when the motor is running then you know that the heater relay contacts are not closing.
File Attachment(s):
GEW9250.pdf (357kb) downloaded 8 time(s).
jammaker
#3 Posted : Friday, May 13, 2011 6:31:02 AM(UTC)
jammaker
My mistake, it is 11.3K ohms not 11.3. Traced it down to a faulty breaker that lost power on the one leg:( It was a cheap fix this time :)
Coin operated Gas Dryer doesn't heat on 2nd cycle (Dryer Repair)
by sup 7/13/2017 9:44:31 AM(UTC)
*** HELP!! GE Dryer Doesn't Heat *** (Dryer Repair)
by SkyNet3 2/25/2016 12:46:10 PM(UTC)
Dryer doesn't heat (Dryer Repair)
by SteveDB 4/16/2013 10:47:38 AM(UTC)
Kitchenaid dryer doesn't heat (Dryer Repair)
by Snakebone 11/8/2012 11:40:23 AM(UTC)
by Snakebone 11/8/2012 11:31:10 AM(UTC)
Maytag Neptune-Dryer doesn't heat up (Dryer Repair)
by See Jane Run! 7/24/2012 3:27:30 PM(UTC)
Dryer doesn't heat properly. (Dryer Repair)
by pnoe 2/19/2012 1:18:10 PM(UTC)
by Sandysalter 10/29/2011 2:41:21 PM(UTC)
Maytag Neptune Gas dryer doesn't heat (Dishwasher Repair)
by kmc1214 4/8/2011 8:00:44 AM(UTC)
Anana Dryer Doesn't Heat (Dryer Repair)
by dhs51 2/8/2011 3:26:11 PM(UTC)
Electric Dryer Doesn't heat up (Dryer Repair)
by yomeropistolero 1/16/2011 9:57:44 PM(UTC)
Dryer doesn't heat properly (Dryer Repair)
by kevin.m.elkin@rrd.com 12/7/2010 7:41:41 PM(UTC)
by briggins8 10/9/2010 3:48:45 PM(UTC)
Gas Dryer doesn't heat up - but that isn't my issue (Dryer Repair)
by mitch8 10/6/2010 11:04:27 AM(UTC)
Dryer doesn't heat up and moisture sensor not indicating wet clothes (Dryer Repair)
by Joan Cartier 10/3/2010 5:58:52 AM(UTC)
