edwin3711
#1 Posted : Monday, November 10, 2008 8:59:32 PM(UTC)
edwin3711
:confused: hi,my kenmore washer fills normal and starts washing,but when it gets to the next task (pause cool down or rinse or spin)it stops working.
I have to advance it manually to the next task.
I replaced the timer,because i was told that was the solution...it was not.
Can you help me please?
#2 Posted : Tuesday, November 11, 2008 1:02:20 AM(UTC)
When the washer stops, can you get it to run right away. If not, you have an overheating motor that's probably bad. You can pull the motor out and check operation to see if it still overheats .
edwin3711
#3 Posted : Tuesday, November 11, 2008 7:19:14 AM(UTC)
edwin3711
yes,it starts right away,what is not doing at all is rinsing,even if i advance it manually.
it washes,spins,fills normally......when it gets to rinse...stops and when it gets to pause cool down task,which is one of the tasks before rinsing on -permanent press ll -it just wont advance.
my main problem is that is not rinsing at all.
thank you very much,really appreciate your help.
magician59
#4 Posted : Tuesday, November 11, 2008 8:16:15 AM(UTC)
magician59
Check your water supply valve. It may be clogged on the cold side.
edwin3711
#5 Posted : Tuesday, November 11, 2008 9:58:37 AM(UTC)
edwin3711
I believe you found the solution,hot water goes in but cold water doesn't.
there is an external trap or filter,i cleaned it up,but there must still be an internal trap that is clogged up....how do i get to it?
thanks.
edwin3711
#6 Posted : Tuesday, November 11, 2008 1:37:38 PM(UTC)
edwin3711
fixed the problem,cold water supply was disrupted,replaced faulty inlet valve.
now it works like new.
Thank you very,very much,couldn't do it without you.
Dishwasher stops in middle of cycle and has draining problems (Dishwasher Repair)
by Guest 12/21/2022 1:34:11 PM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Frigidaire FTF530 Washer Stops Randomly During Wash Cycle (Dishwasher Repair)
by jensenpe 10/11/2021 7:28:24 AM(UTC)
Bosch dishwasher stops at beginning of cycle (Dishwasher Repair)
by Daniel J 2/23/2021 10:39:24 PM(UTC)
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Washer Stops Spinning Abruptly or Doesn't Spin At All (Washer Repair)
by ggarcia 3/28/2020 9:20:13 AM(UTC)
Maytag dishwasher stops filling then shuts down (Dishwasher Repair)
by fordguy101 11/2/2018 6:58:19 PM(UTC)
Washer stops agitating mid cycle - F7E5 shifter fault (Washer Repair)
by Phil915 9/15/2018 2:45:38 PM(UTC)
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
Washer Stops before pump and spin (Washer Repair)
by tomwing 3/25/2016 1:40:09 PM(UTC)
Maytag washer stops agitating in wash cycle (Washer Repair)
by Teggy87 12/6/2015 8:51:20 AM(UTC)
Washer Stops during Sensing Mode (Washer Repair)
by gotimmygo89 10/5/2015 7:12:57 AM(UTC)
