I received the F2 E6 error code so followed some of the instructions relating to that on this site:
First testing to see if it is the touch pad or control. -removed the touch pad from the contol and received the error code F2 E1. -Reattached the touch pad and continue to get the same error code.
Does that mean that the control board is bad (because it is not recognizing that the pad is attached) or that the pad is bad?
I have tried to reattach the touch bad a few different times thinking that it may not have been inserted all the way but continue to get the same error....
The double oven is black with Stainless steel.
Thanks for any help.
Hello,
It's been awhile, and I'm betting you found your answer already, but just in case.....
I have a Whirlpool Gold Dbl oven and got the same error code. Turns out we need to replace the clock board.
Hope this helps.
