mtheeuwes
#1 Posted : Sunday, October 5, 2008 8:13:30 AM(UTC)
mtheeuwes
I received the F2 E6 error code so followed some of the instructions relating to that on this site:
First testing to see if it is the touch pad or control.
-removed the touch pad from the contol and received the error code F2 E1.
-Reattached the touch pad and continue to get the same error code.
Does that mean that the control board is bad (because it is not recognizing that the pad is attached) or that the pad is bad?
I have tried to reattach the touch bad a few different times thinking that it may not have been inserted all the way but continue to get the same error....
The double oven is black with Stainless steel.
Thanks for any help.
Tinka
#2 Posted : Monday, November 10, 2008 6:07:31 PM(UTC)
Tinka
Hello,
It's been awhile, and I'm betting you found your answer already, but just in case.....
I have a Whirlpool Gold Dbl oven and got the same error code. Turns out we need to replace the clock board.
Hope this helps.
Whirlpool Double oven diagnostic mode (Oven Repair (including Ranges and Cooktops))
by webjunk78230 8/29/2022 1:37:43 PM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by cwsunderland 4/4/2021 5:00:24 AM(UTC)
Whirlpool double oven RBD305PDQ14 (Oven Repair (including Ranges and Cooktops))
by ReeseReed0415 4/21/2020 7:15:22 AM(UTC)
Whirlpool double oven mounted in wall cabinets (Oven Repair (including Ranges and Cooktops))
by Redeyebob 12/30/2019 10:31:52 AM(UTC)
My whirlpool double oven won’t turn on (Oven Repair (including Ranges and Cooktops))
by Zuvdog 12/23/2019 8:38:06 AM(UTC)
Whirlpool Double Oven - Bottom Not Working (Oven Repair (including Ranges and Cooktops))
by kanderna 3/24/2018 9:58:57 AM(UTC)
Dead Display Whirlpool Double Oven (Oven Repair (including Ranges and Cooktops))
by chatenever 12/14/2017 6:51:55 AM(UTC)
Whirlpool Double Oven - Control Board & Door latch assembly??? (Oven Repair (including Ranges and Cooktops))
by Bhauer 6/6/2017 7:09:43 PM(UTC)
Whirlpool double oven display blank (Oven Repair (including Ranges and Cooktops))
by krupp 3/26/2016 7:01:29 AM(UTC)
How do I access control panel - Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by technogal54 3/6/2016 8:32:18 AM(UTC)
Whirlpool Double Oven Error Code - Help (E6 F2 and E1 F2) (Oven Repair (including Ranges and Cooktops))
by trvsthbdx 8/24/2015 7:46:08 PM(UTC)
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
Whirlpool Double Oven Blank Display (Oven Repair (including Ranges and Cooktops))
by RDLearned 1/26/2015 3:20:49 PM(UTC)
