donandlynn
#1 Posted : 14 years ago
donandlynn
My washer is leaking water from the bottom. I have a this problem before and the repair man said it was a filter that gets clog up and causes it to leak. I also called the samsung repair center and they said it would be found in the drain hose. I found a rubber black part not sure if that's it or not. I hope we can fix this without calling to have it repair. Thanks Lynn
sidfink43
#2 Posted : 14 years ago
sidfink43
Not a lot of experience with working on these models so about the best I can do is link you to a repair manual for a model that should be similar to yours.
https://secured.whirlpoo...sung_Frontier_Washer.pdf
Hope this helps.
Leaking Washer (Washer Repair)
by midget73 11 years ago
by broonsparrow 11 years ago
Leaking washer need advice (Washer Repair)
by GE Nightmare 12 years ago
leaking washer (Washer Repair)
by ashkdaot 12 years ago
by Jags 12 years ago
by martha725 13 years ago
leaking washer and won't drain (Dishwasher Repair)
by colt 13 years ago
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 13 years ago
Leaking washer (Washer Repair)
by Crowell 14 years ago
leaking washer during filling (Washer Repair)
by bonnetinsurance 14 years ago
by 03svrider 14 years ago
by rcarroll7703 14 years ago
by Mrkis 14 years ago
by Clueless101 14 years ago
by wirenutt2 14 years ago
