Douglas Ressler
#1 Posted : Sunday, November 2, 2008 4:36:40 PM(UTC)
Douglas Ressler
WHEN ON THE RINSE OR SPIN CYCLE THE WATER SEEMS TO BE COMING OUT OF THE TOP OF TUB and then onto my floor! Any Suggestions?
Also we ended up turning back our water level because of this which of course now my loads aren't near as full and with a family of five laundry is taking too long to do Please Help!:( :confused: ;)
v2k04
#2 Posted : Sunday, November 2, 2008 5:07:39 PM(UTC)
v2k04
when the brake pads wear out it will agitate and spin at the same time making water flood over, or its not pumping it out fast enough or the belt is shot or its overfilling in wash all of these things need checked eliminating it down to which it is does that make sense? lol
Butch17fan
#3 Posted : Saturday, April 23, 2011 9:11:23 PM(UTC)
Butch17fan
Am having the same problem..Mine was coming out of the filler tube from the soap dish to the tub. I hope that helps.
access13955
#4 Posted : Thursday, April 10, 2014 7:16:52 AM(UTC)
access13955
The top of the transmission casing is connected to the basket, and during the spin cycle, the whole transmission rotates. Slippage in the belt, allowed by the tensioner, permits a "pre-pump" action, allowing the basket to come slowly up to speed. if not water will overflow to top of tub on to the motor caused shortage.
The bottom of the transmission casing is connected to a brake. This brake is activated by a helix in the hub of the transmission pulley. During the agitate cycle, the brake engages and prevents the transmission casing (and thus the basket) from turning. During the spin cycle, the helix mechanism releases the brake and the whole transmission spins around. happy fixing!!!:D :D :D
Guest (5)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Speed Queen shaft wear (Washer Repair)
by fredgilb 4/29/2024 3:11:05 PM(UTC)
Speed Queen top load washer model AWN412SP111TW01 (Washer Repair)
by Guest 4/28/2024 6:36:53 PM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
Speed Queen Washer makes random squeaking noise (Washer Repair)
by Guest 2/10/2024 7:29:00 AM(UTC)
Speed Queen top load washer model AWNE82SP113TW01 (Washer Repair)
by Guest 2/2/2024 10:12:50 AM(UTC)
Speed Queen top load washer modelAWN542SP111TW01 (Washer Repair)
by Guest 1/27/2024 10:43:32 AM(UTC)
Speed Queen top load washer model AWN542SP111TW01 (Washer Repair)
by Guest 1/13/2024 1:28:32 AM(UTC)
Speed Queen top load washer (Washer Repair)
by Guest 12/24/2023 4:29:03 AM(UTC)
by Guest 12/23/2023 3:02:14 AM(UTC)
Speed Queen top load washer typical model AWNE82SP113 (Dryer Repair)
by Guest 12/1/2023 8:26:13 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Speed Queen top load commercial coin type washer model SWT121WM (Washer Repair)
by Guest 11/11/2023 7:24:23 AM(UTC)
Speed Queen top load washer model AWS17NW (Washer Repair)
by Guest 10/16/2023 11:23:35 AM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
