Washer Will Agitate But Will Slow Down And Cut Off Same With Spin Cycle .i Also Here A Clicking Noise When It Slows Down.have Changed The Mount On Motor Please Help.
From the description, might be a burnt wire someplace, a bad timer,or a bad motor, this assumes the washer acts up in agitate also. I would pull the cover off the timer and check for bad contacts.
I checked terminal connections throughout my Whirlpool LXR9445JQO and found no problems. I put a new $100 timer in and it still fails mid-cycle. Please advise.
Do the tranny coupler test to check the brakes in my sticky "Replacing direct drive washer brake shoes".
