jking
#1 Posted : Monday, April 11, 2011 8:53:35 AM(UTC)
jking
Washer Will Agitate But Will Slow Down And Cut Off Same With Spin Cycle .i Also Here A Clicking Noise When It Slows Down.have Changed The Mount On Motor Please Help.
sidfink43
#2 Posted : Wednesday, April 13, 2011 7:55:34 AM(UTC)
sidfink43
Use the Sticky at the top of the page on direct drive brakes and this video
YouTube - Washing Machine Clutch Band and Lining Repair Kit Replacement (part #285790)
to check out and change the clutch and check the brakes.
#3 Posted : Wednesday, April 13, 2011 8:27:09 AM(UTC)
From the description, might be a burnt wire someplace, a bad timer,or a bad motor, this assumes the washer acts up in agitate also.
I would pull the cover off the timer and check for bad contacts.
MarkSchultz
#4 Posted : Thursday, April 14, 2011 7:00:38 AM(UTC)
MarkSchultz
I checked terminal connections throughout my Whirlpool LXR9445JQO and found no problems. I put a new $100 timer in and it still fails mid-cycle. Please advise.
#5 Posted : Thursday, April 14, 2011 2:09:15 PM(UTC)
Do the tranny coupler test to check the brakes in my sticky "Replacing direct drive washer brake shoes".
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
