radicioni
#1 Posted : Tuesday, October 28, 2008 6:51:49 PM(UTC)
radicioni
Kenmore model 665 16708
turn manual knob to normail wash water will fill and then it stops. will not cycle, will not drain.
Changed out timer, air gap no clog in hose
Help
#2 Posted : Thursday, October 30, 2008 11:55:21 AM(UTC)
Remove the bottom panel and check the motor. If there was a slow water leak and motor is rusted, then the pump & motor assembly has to be replaced.
P.S. The model number you posted is incomplete.
radicioni
#3 Posted : Thursday, October 30, 2008 12:08:16 PM(UTC)
radicioni
Gene, when I remove the bottom panel there is some water dripping where the drain hose is when I turn the motor.
I quess its time for a new one.
Will not drain on spin cycle (Washer Repair)
by Guest 8/7/2022 8:04:16 AM(UTC)
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Kenmore Model 665.13269K110 will not drain (Dishwasher Repair)
by LoserKorn 4/14/2019 1:21:36 PM(UTC)
Ge dishwasher will not drain (Dishwasher Repair)
Belarus Handyman924 2/24/2017 8:05:27 PM(UTC)
Samsung Front Loader will not drain (Washer Repair)
by orangecrush 4/18/2016 6:32:48 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
Whirlpool stops after wash cycle will not drain or spin (Washer Repair)
by JF2015 1/4/2015 7:19:52 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
maytag will not drain (Washer Repair)
by john rodriguez 7/15/2014 8:28:54 PM(UTC)
Maytag atlantis will not drain or spin (Washer Repair)
by Militoni 7/12/2014 3:34:57 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
Whirlpool QPII not bringing in water, also will not drain (Dishwasher Repair)
by hawkeye680 11/2/2013 9:13:43 AM(UTC)
