tmohler
#1 Posted : Wednesday, October 29, 2008 3:36:06 PM(UTC)
tmohler
My dryers heating element stays on through no heat ,and cool down cycle any ideas thanks
libertyappl
#2 Posted : Wednesday, October 29, 2008 3:41:37 PM(UTC)
libertyappl
Probably the cycling thermostat or a short in the wiring is probably the best place to start.
Nat
Drags1998
#3 Posted : Wednesday, October 29, 2008 4:53:10 PM(UTC)
Drags1998
The other possibility is the heater is SHORTED to ground.
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Whirlpool Estate Dryer (Dryer Repair)
by Bob Castles 6/11/2016 1:26:44 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
Estate dryer won't heat, all the thermosats and heating elements good (Dryer Repair)
by Tim2020 4/26/2014 7:52:57 PM(UTC)
estate dryer wont shut off (Dryer Repair)
by centerville1966 2/15/2014 1:39:29 PM(UTC)
Estate dryer not heating up (Dryer Repair)
by Jackier 8/6/2013 5:23:00 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Estate dryer looses flame once it hits the 40 min spot on dial (Dryer Repair)
by goetso 11/14/2012 1:29:27 PM(UTC)
Estate dryer won't start, replaced thermal fuse still not working (Dryer Repair)
by cassnbruce52607@aol.com 11/10/2012 6:04:51 PM(UTC)
Estate Dryer Heats Up But Motor Stopped (Dryer Repair)
by krSRinPA 7/5/2012 7:22:14 AM(UTC)
Estate Dryer will not start (Dryer Repair)
by drew63 6/18/2012 11:11:18 AM(UTC)
Whirlpool estate dryer making noise (Dryer Repair)
by sullivanwi1 6/2/2012 7:19:36 AM(UTC)
by kbollen 3/21/2012 6:57:44 PM(UTC)
whirlpool estate dryer (Dryer Repair)
by estatedryer 12/29/2011 4:26:21 PM(UTC)
by steven acer 12/18/2011 4:34:53 PM(UTC)
