saustin
#1 Posted : Friday, October 24, 2008 4:35:34 PM(UTC)
saustin
The gate shaft seal (diagram #417) is leaking on the pump housing. The leaking water has corroded the solenoid which I have fixed. Can a new seal really fix this problem? It apprears the shaft has some movement in it which may be the reason the seal failed. Seals are cheap and the push nut (diagram #415), but not sure if it will work. Thanks for any help.
#2 Posted : Saturday, October 25, 2008 1:20:02 AM(UTC)
You will need to pull out the pump and take off the solenoid bracket, then dig out the bad seal and replace it AP2038837
EGH
#3 Posted : Friday, May 1, 2009 6:29:52 AM(UTC)
EGH
You mention dig out the bad seal. I'm preparing to do the exact task with part # AP2038837. Any trick to "digging" out the bad seal?
Thanks for any info.
EGH
#4 Posted : Friday, May 1, 2009 7:33:06 AM(UTC)
You can try just sticking the new "O" ring in on top of the old seal, if no go, try a tiny screw driver to dig it out.
EGH
#5 Posted : Friday, May 1, 2009 8:52:18 AM(UTC)
EGH
Thanks, I have a new seal and Push-on nut on order from APP. Sounds like digging it out really means dig it. Removing the push-on-nut is similar? Is the push on nut simply a friction fit? EGH
I just don't want to create futher damage to the area I'm trying to seal.
Thanks again ;)
GE Profile Performance Side by Side Refrig/Freezer (Refrigerator & Freezer Repair)
by eviemail 1/30/2011 12:46:15 PM(UTC)
GE Profile Performance Ice Maker Not working (Dishwasher Repair)
by bmurph8 10/21/2010 10:48:26 AM(UTC)
GE Profile Performance Refrigerator (Refrigerator & Freezer Repair)
by patma 8/25/2010 10:54:49 AM(UTC)
by sunal4 8/8/2010 5:18:26 PM(UTC)
Ge profile performance doesn't dispense ice (Refrigerator & Freezer Repair)
by tpease 5/28/2010 7:40:59 AM(UTC)
GE Profile Performance (Electric) Not Heating (Dryer Repair)
by dlwarman 4/5/2009 9:47:00 AM(UTC)
GE Profile Performance freezer ices up (Refrigerator & Freezer Repair)
by emgconsulting 6/28/2008 3:58:47 PM(UTC)
