Mark Renfrow
#1 Posted : Friday, October 24, 2008 11:46:16 AM(UTC)
Mark Renfrow
The washer wont spin or agitate. Water fills and drains. Sounds like the motor is spinning...
Any help would be appreciated.
Can I fix this myself?
libertyappl
#2 Posted : Friday, October 24, 2008 7:58:24 PM(UTC)
libertyappl
Yes, you can, sounds like your coupler broke. If you raise the lid and remove the outer cbinet you, the coupler is located between the pump & motor. If you need to see a parts breakdown you can see one on the searspartsdirect website.
Nat
