When my washer starts running the water keeps running and over fills in the floor:confused:
You will need to check your pressure switch & tube(make sure there are no holes in the tube and no water in the tube) and check the water valve to see if it may be stuck open. Here's the breakdown Model RAL5144BW0 Nat
THANK YOU. You are a big help:cool: . I'm glad I found your help page.
Glad to help. But I just volunteer a little info for this company. I don't work for them. If you need anything else just post. Me or one of the other volunteers will help what we can!! Nat
