mike park
#1 Posted : Friday, October 24, 2008 6:43:08 AM(UTC)
mike park
When my washer starts running the water keeps running and over fills in the floor:confused:
libertyappl
#2 Posted : Friday, October 24, 2008 8:00:00 AM(UTC)
libertyappl
You will need to check your pressure switch & tube(make sure there are no holes in the tube and no water in the tube) and check the water valve to see if it may be stuck open.
Here's the breakdown Model RAL5144BW0
Nat
mike park
#3 Posted : Friday, October 24, 2008 10:03:21 AM(UTC)
mike park
THANK YOU. You are a big help:cool: . I'm glad I found your help page.
libertyappl
#4 Posted : Friday, October 24, 2008 8:00:48 PM(UTC)
libertyappl
Glad to help. But I just volunteer a little info for this company. I don't work for them. If you need anything else just post. Me or one of the other volunteers will help what we can!!
Nat
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
