TPost
#1 Posted : Tuesday, October 21, 2008 6:06:00 PM(UTC)
TPost
My wifes dryer wont heat up. I pulled off the back cover and when I went to check the continuity on the element this is what I got:
When I touched the leads to the conectors for the heating element it showed continuity.
When I touched the leads to the heating element wire just up from the conectors it showed no continuity (open).
Does this make sense? I am pretty sure it is the element but I just want to order the correct part.
Thanks, Todd
libertyappl
#2 Posted : Wednesday, October 22, 2008 9:43:47 AM(UTC)
libertyappl
Test the element by removing the wires at the connectors. Also test the thermal cuttoff the same way. That will tell you if one of them are bad.
Nat
Whirlpool Inglis Dryer Wont Heat Up and Keeps Running (Dryer Repair)
by johnnymac813 1/8/2014 4:39:14 PM(UTC)
Dryer Wont Heat Up (Dryer Repair)
by SUE KLEIN 8/24/2013 6:22:08 AM(UTC)
dryer wont heat up (Dryer Repair)
by lmyers 3/11/2013 12:31:55 PM(UTC)
Gas dryer wont heat up (Dryer Repair)
by kramler92 12/8/2011 3:14:26 PM(UTC)
by beachrunner 8/15/2011 8:56:07 AM(UTC)
Neptune Dryer wont heat up or dry (Dryer Repair)
by medik3 8/4/2011 8:13:36 AM(UTC)
dryer wont heat up at all (Dryer Repair)
by dcquick1096 12/2/2010 7:30:44 AM(UTC)
Dryer wont heat up (Dryer Repair)
by ktventura1989@yahoo.com 7/9/2010 2:32:48 PM(UTC)
Whirlpool Elec Dryer wont heat up (Dryer Repair)
by Canute 2/9/2010 3:16:11 PM(UTC)
by tam4572@aol.com 2/7/2010 3:22:11 AM(UTC)
dryer wont heat up? (Dryer Repair)
by jreich77 11/1/2009 4:33:01 PM(UTC)
by trish949 9/26/2009 7:33:08 AM(UTC)
Ge dryer wont heat up (Dryer Repair)
by CLARK12 8/2/2009 12:36:31 PM(UTC)
by poelease 6/4/2009 8:22:16 AM(UTC)
by NYSE Bob 5/21/2009 5:33:26 PM(UTC)
