puttputt1953
#1 Posted : Sunday, October 19, 2008 8:18:14 PM(UTC)
puttputt1953
washer leaks water when it starts to agitate. can anyone help me?:(
#2 Posted : Monday, October 20, 2008 1:27:21 AM(UTC)
Pull the front panel and tell us where it is leaking. If a vinyl tub with leaking tub seal, it's not worth fixing.
puttputt1953
#3 Posted : Monday, October 20, 2008 10:19:26 AM(UTC)
puttputt1953
leaking between agiater and transmission. is there a seal that could be leaking and if so do you have to drop the transmission?
#4 Posted : Tuesday, October 21, 2008 12:51:45 AM(UTC)
Do you have a plastic tub?
puttputt1953
#5 Posted : Tuesday, October 21, 2008 9:13:59 AM(UTC)
puttputt1953
sorry, I do not have a plastic tub.
#6 Posted : Tuesday, October 21, 2008 12:18:11 PM(UTC)
You can go to web site www.applianceaid.com for repair info on this rather difficult job to replace the tub seal/bearing.
Guest (6)
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 9/21/2020 9:46:26 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer leaks water while filling tub (Washer Repair)
by 2WHIRLPOOLSCLW 5/26/2013 4:57:28 PM(UTC)
Washer leaks water into tub continuously (Washer Repair)
by jray66cj 3/8/2012 5:47:01 PM(UTC)
washer leaks water into basket when not in use (Washer Repair)
by anne stromberg 7/2/2011 5:14:35 AM(UTC)
during spin washer leaks water from under nealth (Washer Repair)
by 21jam12 2/3/2010 6:03:43 AM(UTC)
washer leaks water out bottom (Washer Repair)
by jag11727 5/9/2009 7:36:08 AM(UTC)
dishwasher leaks water occasionally (Dishwasher Repair)
by jukenut 4/26/2009 6:40:48 PM(UTC)
washer leaks water (Washer Repair)
by centurionballer 11/20/2008 10:29:38 AM(UTC)
Washer Leaks Water Into Tub After Cycle (Washer Repair)
by zinnco 7/29/2008 7:21:02 AM(UTC)
by watson-1 2/27/2008 7:12:57 AM(UTC)
