rocco
#1 Posted : Tuesday, October 9, 2007 6:35:28 AM(UTC)
rocco
Hello,
My washer has a water leak at the outside of the tub. It seams to be leaking at the point where the two halves of the tub are screwed together. I bought the gasket from sears that the parts diagram shows sits between the two halves. I first tried tightening the screws but that did not stop it and since everything is plastic I felt it would be better to replace gasket. Now I'm trying to figure out how to take this apart to change the gasket. What's the best way to do this? From front,back, top? Do I have to take the drum completely out?
Another issue: Someone told me that the shocks break alot in front loaders and that sears knows about this and has changed the design to metal shocks instead of plastic. Should I check with sears about updated designs?
Also, is there a service manual out there that is specific to my washing machine?
Thank You
#2 Posted : Thursday, October 11, 2007 1:30:33 AM(UTC)
You have a Frigidaire front loader. Go to Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help, to get gasket replacement instructions. This is a lot of labor, but not too difficult and no special tools needed.
Inspect the inner spin basket support spider for rust while apart, and check the bearings for leakage.
Click on your model # for parts.
rocco
#3 Posted : Saturday, October 13, 2007 10:57:13 AM(UTC)
rocco
thanks, just the information I needed.
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
by martha725 8/3/2012 2:11:37 PM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by rcarroll7703 6/1/2011 7:50:27 AM(UTC)
by donandlynn 5/7/2011 7:32:41 AM(UTC)
by Mrkis 1/30/2011 9:09:01 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
