13 Pages«<89101112>»
#91 Posted : Monday, September 27, 2010 3:31:21 PM(UTC)
Lets do one thing at a time and start with the drum not turning.
Quote:
...I have checked the ohms on the motor 3 wires and they are about 6-7 ohms. I plugged a volt meter into the red and blue wires on doing the t10, t11, t14 test and I DO have 120V on the wires but no rotation on the drum...
Most likely the inverter is the culprit.
- The inverter Part number: AP4421584
Replace the inverter and post the results.
dongta
#92 Posted : Wednesday, October 20, 2010 2:18:43 PM(UTC)
dongta
Try to reprogram the control board:
Enter test mode and select t01. Rotate the cycle knob until the correct model
number is displayed:
Select 1 for model WHDVH626F
Select 2 for model WCVH6260F
Select 3 for model WBVH6240F
Press and hold the Start key for 3 seconds (or until a second beep is sounded).
Press the Power key to reset the control.
If it would not help then the control board most likely has to be replaced.
- The part number for the control board assembly is AP3995160
Hi Gene,
After I
"Press and hold the Start key for 3 seconds (or until a second beep is sounded).
Press the Power key to reset the control."
What are we looking for? A beep, an error code, etc?:confused:
Thanks.
Dong
things4u2
#93 Posted : Wednesday, October 20, 2010 2:54:53 PM(UTC)
things4u2
Gene--thank you for the information. I got the inverter put on and so far has functioned properly for at least 5 loads. Thinking it is now fixed. Again THANK YOU!
#94 Posted : Saturday, October 23, 2010 4:46:57 PM(UTC)
You are welcome. I'm glad you were able to fix it.
tahoetomahawk
#95 Posted : Tuesday, March 22, 2011 9:13:45 AM(UTC)
tahoetomahawk
Hi guys, I'm so happy to have found this forum. I'm in the process of replacing my Inverter for a GE Front Load washer model wbvh6240fww.
I'm stuck on removing it as it only has 1 screw holding it down, after removing the only screw, the inverter moves freely, but is being held in place by the back feet, I don't see any more screws holding it down though. Anyone else have this problem?
#96 Posted : Wednesday, March 23, 2011 12:59:03 PM(UTC)
Slide the inverter rearward to clear the guides that hold the rear of the inverter to the chassis. Then remove the inverter thru the enlarged opening
on the left side of the front frame.
Here are the breakdown diagrams and Replacement parts for General Electric WBVH6240F0WW Washer | AppliancePartsPros.com
tahoetomahawk
#97 Posted : Wednesday, March 23, 2011 2:17:59 PM(UTC)
tahoetomahawk
Hi Gene, thanks. I got it out and put the new Inverter In. The new Inverter also fixed my tumble / spin problem.
The new inverter casing was different than the old casing though, and I cracked the plastic foot trying to slide it into place. I had to secure it down the best I could, but hey.. washing is working again!
#98 Posted : Wednesday, March 23, 2011 2:41:07 PM(UTC)
You are welcome. I'm glad it's up and running.
Thank you for the feedback.
jaa55
#99 Posted : Wednesday, June 1, 2011 4:33:47 AM(UTC)
jaa55
I have a GE front load washer model number WCVH660 that won't spin. I ran test t02 and got error code E48. Then I ran t10 and t11 and nothing happened. When I opened the front cover of the washer, there were 3 white plastic parts broken and laying in the bottom of the cabinet. They are about 4 1/2" long and 3/4" in diameter. I'm not sure if these are just shipping locks or not. Any help would be greatly appreciated!
#100 Posted : Wednesday, June 1, 2011 2:08:06 PM(UTC)
The "E48" error code means "Open motor".
Check the motor as described in the attached file. If the motor is good, replace the inverter.
- The motor Part number: AP3872963
File Attachment(s):
How to test and replace the motor assembly.doc (474kb) downloaded 22 time(s).
How to test and replace the inverter.doc (220kb) downloaded 25 time(s).
ge front load washer won't tumble/spin (Washer Repair)
by Laeloni 3/26/2011 10:07:27 AM(UTC)
