2 Pages<12
Miss Donna
#11 Posted : Tuesday, November 16, 2010 3:11:14 PM(UTC)
Miss Donna
Once angain Thank You.
Originally Posted by: Joe / APP Team Go to Quoted Post
Miss Donna,
The part number for your electronic control board, as you requested:
Part number: AP4434691
That control board is located in the same area as the compressor(where your husband repalced the relay kit)
It (the plastic box) will need to be removed from the base frame, openned,and the printed circuit board removed to replace the board.
** I reccomend you install the new printed circuit board first, then switch the wire harness connectors from the old ,to the new, then install the box back on the base frame. **
Good Luck,
Joe / APP Team
#12 Posted : Wednesday, November 17, 2010 5:04:49 AM(UTC)
Joe / APP Team
You're welcome, Again
Keep in touch.
Miss Donna
#13 Posted : Tuesday, March 15, 2011 2:08:07 PM(UTC)
Miss Donna
My husband replaced both parts mentioned above and it worked fine for sometime but now the same problem is happening do you have any other suggestions on how we might handle this problem.
Thank You
Joe / APP Team
#14 Posted : Wednesday, March 16, 2011 6:38:52 AM(UTC)
Joe / APP Team
Thank You
Miss Donna,
Have your husband try this,
He'll need access to a multi meter
Part number: AP3873826
At the compressor, when the noise is present, he needs to check for 120 VAC across the Blue wire and the White wire on the overload/relay assembly.
I would also check from the Blue wire and the White wire to chassis ground (a screw or bare metal spot on the frame)for the same voltage.
As long as we maintain at least 108 VAC on both checks, and since you have new relay assembly and control board, I would have to presume, the compressor windings are going bad.
Miss Donna
#15 Posted : Thursday, March 17, 2011 9:18:26 AM(UTC)
Miss Donna
Miss Donna,
Okie Dokie, we shall try this, once again thank you and will let you know what we find. :p
Joe / APP Team
#16 Posted : Thursday, March 17, 2011 10:09:46 AM(UTC)
Joe / APP Team
Miss Donna,
Great deal,
I'll keep an eye out for your next post,
We'll have a better idea after the checks your husband makes.
and can go from there.
GE french door refrigerator not dispensing water (Refrigerator & Freezer Repair)
by Guest 12/1/2023 5:51:32 AM(UTC)
Frigidaire Gallery French Door Refrigerator (Refrigerator & Freezer Repair)
by Guest 11/19/2023 2:36:25 PM(UTC)
LG french door refrigerator ice maker fan not working (Refrigerator & Freezer Repair)
by md5757 11/6/2023 11:27:11 AM(UTC)
Kitchen Aid French door refrigerator KRFF302ESS03 - Freezer (Refrigerator & Freezer Repair)
by dieselgg 8/28/2023 5:31:49 AM(UTC)
2013 GE Adora french door refrigerator dispenser issue (Refrigerator & Freezer Repair)
by ladmo19013 6/17/2023 11:48:11 AM(UTC)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Samsung French Door Refrigerator RF28R6301SR/AA Freezer getting too Cold (Refrigerator & Freezer Repair)
by BlueCrabs 12/6/2021 4:29:26 AM(UTC)
GE profile French door refrigerator issue (Refrigerator & Freezer Repair)
by Jack_2020 1/16/2021 1:57:17 PM(UTC)
Kitchen aide french door refrigerator. (Refrigerator & Freezer Repair)
by Rvrfshr 12/13/2020 12:19:39 PM(UTC)
Maytag French Door Refrigerator - Occasionally colder than setpoint (Refrigerator & Freezer Repair)
by DuaneA 7/11/2020 10:22:31 AM(UTC)
Whirlpool French Door Refrigerator (Refrigerator & Freezer Repair)
by dbdata 5/23/2020 10:44:03 AM(UTC)
How do you reinstall the auto filter bypass plug on LG French Door refrigerator? (Refrigerator & Freezer Repair)
by eurohop 10/16/2015 8:18:39 AM(UTC)
Maytag french door refrigerator icemaker problems (Refrigerator & Freezer Repair)
by jamie_pancake@yahoo.com 8/13/2015 3:44:09 AM(UTC)
Kenmore French door Refrigerator won't dispense ice (Refrigerator & Freezer Repair)
by decollins 7/22/2014 7:14:49 PM(UTC)
2 Pages<12
