2 Pages12>
triciajenkins
#1 Posted : Friday, October 8, 2010 5:35:45 AM(UTC)
triciajenkins
Two days ago I noticed a buzzing sound coming from my refrigerator. Every few minutes the buzzing starts and stops. This morning everything in my freezer has thawed and the top portion of the refrigerator is warm. The buzzing just stopped a few minutes ago. Help!
Joe / APP Team
#2 Posted : Friday, October 8, 2010 1:06:29 PM(UTC)
Joe / APP Team
Tricia,
Where was the noise coming from, front, back, top, bottom ?
And a model number would help, a lot.
Thanks,
:cool: :cool: :cool:
Miss Donna
#3 Posted : Monday, October 11, 2010 9:55:36 AM(UTC)
Miss Donna
MAYTAG, Model # MFD2561HEW
I,m haveing the same problem called a repairman but he knew nothing about the unit and suggested unpluging it so it could reboot its self, we did and it works for a while, the last time I unpluged it was about 2 weeks ago at 2am when I got up to let the dogs out and then pluged it back in when I got up around 7 am this morning when my husband got up the temps were up, don't want to have to keep unpluging it every couple of days or weeks.
Joe / APP Team
#4 Posted : Monday, October 11, 2010 10:40:31 AM(UTC)
Joe / APP Team
Well,
Most likely,
You have an intermittent problem in your electronic control board or compressor start circuitry(relay).
Both of those components are located on the back of the refrigerator, in the right rear corner(looking at the machine from the front).
Next time it makes the noise, try and isolate the noise to the components before you reset the control.
Let us know what you find, where the noise is and we can help you from there.
Miss Donna
#5 Posted : Monday, October 11, 2010 11:10:26 AM(UTC)
Miss Donna
Thank you for such a quick response, I will have my Husband pull the fridge out and check it and let you know what we find.
Once again Thank You so much
Miss Donna
Joe / APP Team
#6 Posted : Monday, October 11, 2010 1:52:41 PM(UTC)
Joe / APP Team
Miss Donna
Miss Donna,
You're welcome,
Hopefully we'll hear from you soon and get yopu up and going, properly.
Miss Donna
#7 Posted : Saturday, October 30, 2010 8:39:45 PM(UTC)
Miss Donna
Ok, I think I have isolated the noise to the compressor, it sounds like it is comeing from the conection plug, now as far as resetting the control, is there something I should be doing besides just unplugging the unit.
Do I need to call a repair man or could my husband replace the compressor if the is what it is?
Looking forward to hearing from you,
Miss Donna:(
Joe / APP Team
#8 Posted : Monday, November 1, 2010 9:10:41 AM(UTC)
Joe / APP Team
Miss Donna:(
Miss Donna,
A compressor replacement, is something your husband is not eqipped to do.
It requires special tools,guages,meters and refrigerant.
Let's hope, it is just a loose connection or a bad start relay / overload assembly, you make it sound as, he should be able to handle that.
Part number: AP4079373
It could be a "main control" board, but start at the relay/overload.
Good Luck,
Miss Donna
#9 Posted : Tuesday, November 16, 2010 12:03:25 PM(UTC)
Miss Donna
I ordered the part ,#AP4079373, and received it about 2 weeks ago but the fridge was working fine until last night so my husband just replaced the part this morning and about 3 or 4 hours after it was replaced it started makeing the noise again and the temp began to climb, so now I'm assumeing that the main control board needs to be replaced, correct ?
could you be so kind as to let me know what part # that is.
Thank You so much,
Miss Donna
Joe / APP Team
#10 Posted : Tuesday, November 16, 2010 2:38:38 PM(UTC)
Joe / APP Team
Thank You so much,
Miss Donna
Miss Donna,
The part number for your electronic control board, as you requested:
Part number: AP4434691
That control board is located in the same area as the compressor(where your husband repalced the relay kit)
It (the plastic box) will need to be removed from the base frame, openned,and the printed circuit board removed to replace the board.
** I reccomend you install the new printed circuit board first, then switch the wire harness connectors from the old ,to the new, then install the box back on the base frame. **
Good Luck,
GE french door refrigerator not dispensing water (Refrigerator & Freezer Repair)
by Guest 12/1/2023 5:51:32 AM(UTC)
Frigidaire Gallery French Door Refrigerator (Refrigerator & Freezer Repair)
by Guest 11/19/2023 2:36:25 PM(UTC)
LG french door refrigerator ice maker fan not working (Refrigerator & Freezer Repair)
by md5757 11/6/2023 11:27:11 AM(UTC)
Kitchen Aid French door refrigerator KRFF302ESS03 - Freezer (Refrigerator & Freezer Repair)
by dieselgg 8/28/2023 5:31:49 AM(UTC)
2013 GE Adora french door refrigerator dispenser issue (Refrigerator & Freezer Repair)
by ladmo19013 6/17/2023 11:48:11 AM(UTC)
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Samsung French Door Refrigerator RF28R6301SR/AA Freezer getting too Cold (Refrigerator & Freezer Repair)
by BlueCrabs 12/6/2021 4:29:26 AM(UTC)
GE profile French door refrigerator issue (Refrigerator & Freezer Repair)
by Jack_2020 1/16/2021 1:57:17 PM(UTC)
Kitchen aide french door refrigerator. (Refrigerator & Freezer Repair)
by Rvrfshr 12/13/2020 12:19:39 PM(UTC)
Maytag French Door Refrigerator - Occasionally colder than setpoint (Refrigerator & Freezer Repair)
by DuaneA 7/11/2020 10:22:31 AM(UTC)
Whirlpool French Door Refrigerator (Refrigerator & Freezer Repair)
by dbdata 5/23/2020 10:44:03 AM(UTC)
How do you reinstall the auto filter bypass plug on LG French Door refrigerator? (Refrigerator & Freezer Repair)
by eurohop 10/16/2015 8:18:39 AM(UTC)
Maytag french door refrigerator icemaker problems (Refrigerator & Freezer Repair)
by jamie_pancake@yahoo.com 8/13/2015 3:44:09 AM(UTC)
Kenmore French door Refrigerator won't dispense ice (Refrigerator & Freezer Repair)
by decollins 7/22/2014 7:14:49 PM(UTC)
2 Pages12>
