KSimmons
#1 Posted : Saturday, February 12, 2011 10:31:01 AM(UTC)
KSimmons
We recently replaced the EOC board. Now the oven does not heat properly. It was working fine for about amonth after replacing the EOC. Now when set at 350 is only get to about 290
#2 Posted : Sunday, February 13, 2011 2:53:18 AM(UTC)
Replacement parts for FRIGIDAIRE FEF387WJCA Frigidaire/electric Range | AppliancePartsPros.com
Here is tha wiring diagram.
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316002706.pdf
I am assuming that the stove top runs OK and that the oven never comes ready.
If the above are true then the first thing to check is that both elements are working.
Could be just a burned out element.
Most units use both elements during preheat usually switching back and forth between them.
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Top oven not heating properly (Oven Repair (including Ranges and Cooktops))
by crzyred59 10/25/2015 3:05:35 PM(UTC)
Whirlpool Oven Not Heating Properly (Oven Repair (including Ranges and Cooktops))
by Crash55 1/30/2013 2:08:45 PM(UTC)
older ge oven not heating properly (Oven Repair (including Ranges and Cooktops))
by kris23 2/13/2012 7:11:49 PM(UTC)
Issue with oven not heating properly (Oven Repair (including Ranges and Cooktops))
by LOISANN 1/29/2012 5:46:15 AM(UTC)
Admiral oven not heating properly (Oven Repair (including Ranges and Cooktops))
by scotttheis 5/4/2011 11:44:12 AM(UTC)
by cougar1963 10/29/2010 7:34:18 AM(UTC)
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 3/17/2010 4:47:18 PM(UTC)
by Jinsmom 1/11/2010 3:48:03 PM(UTC)
Kenmore Dual Fuel - OVEN NOT HEATING PROPERLY (Oven Repair (including Ranges and Cooktops))
by chaznsc 11/19/2009 2:09:20 PM(UTC)
by harry foy 12/16/2008 7:36:19 AM(UTC)
kenmore oven not heating properly (Oven Repair (including Ranges and Cooktops))
by harrymckee 8/16/2008 11:49:48 AM(UTC)
by naholter 12/12/2007 7:22:03 AM(UTC)
by harry-homeowner 8/3/2007 12:38:54 PM(UTC)
