harry foy
#1 Posted : 16 years ago
harry foy
Huge ball of lightning struck near my house. Sump pump quit. Oven quit. Either or neither my be a result of surge. Maybe a coincidence. Anyway, not knowing the oven wasn't working, I hit bake and preset first. After a few minutes I increased to 500 deg. to cook pizza. Didn't pay any attention to it. After 10 minutes or so I went to use gas burners and no ignitor. All power was off. Blew circuit breaker. Reset, turned oven on again. Temp would only go to 260, and it took a while. Tried broiler. Only would get partial heat. Neither element would give out normal heat. Baking element is only 2 months old. Broiling element is oringinal and is 2 years old. My question is, can an element be bad if it does produce heat, although not maximum heat? How about thermostat? Thanks for any help.
abadfish66
#2 Posted : 16 years ago
abadfish66
The very first thing I would check is the power. Sounds like you don't have 240volts to the oven, could be a bad breaker. Check the oven where the power cord attaches for a bad connection. Check the outlet with a meter for 240 volts
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9 years ago
Top oven not heating properly (Oven Repair (including Ranges and Cooktops))
by crzyred59 9 years ago
Whirlpool Oven Not Heating Properly (Oven Repair (including Ranges and Cooktops))
by Crash55 12 years ago
older ge oven not heating properly (Oven Repair (including Ranges and Cooktops))
by kris23 13 years ago
Issue with oven not heating properly (Oven Repair (including Ranges and Cooktops))
by LOISANN 13 years ago
Admiral oven not heating properly (Oven Repair (including Ranges and Cooktops))
by scotttheis 14 years ago
by KSimmons 14 years ago
by cougar1963 14 years ago
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 15 years ago
by Jinsmom 15 years ago
Kenmore Dual Fuel - OVEN NOT HEATING PROPERLY (Oven Repair (including Ranges and Cooktops))
by chaznsc 15 years ago
kenmore oven not heating properly (Oven Repair (including Ranges and Cooktops))
by harrymckee 17 years ago
by naholter 17 years ago
by harry-homeowner 18 years ago
