harry-homeowner
#1 Posted : Friday, August 3, 2007 12:38:54 PM(UTC)
harry-homeowner
I own a Whirlpool range that is 3 yrs. old. I noticed the other day I went to fix a meal, I preheated the oven, and put the food in the oven. I waited 14mins per package directions, when I went to get the food out the oven was not even hot; however, the stove works fine.
Is it the thermocoupler or the igniter? Is that the proper part name? :confused:
Harry -homeowner
#2 Posted : Saturday, August 4, 2007 9:44:44 PM(UTC)
harry-homeowner
The first thing you do is a visual test. Turn the oven thermostat on, wait at least 30 seconds and take a look at the igniter. It should glow very bright red, almost close to white. Normal time for the igniter to open the gas burner valve and to light up the burner is between 40 second to 1 minute. If it glows red but not bright and even if it does light up the burner but it takes more than a minute, the igniter is bad and has to be replaced. If it does not glow at all, remove the power from the oven, remove the igniter wires and check for continuity between these wires. If there is no continuity, replace the igniter. The part number for the new igniter is AP3129373
If the igniter is not the issue let me know and we will proceed with further diagnosis.
Just for your references here is the break down diagrams for Whirlpool range Model SF303PEKQ0
Good luck.
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Top oven not heating properly (Oven Repair (including Ranges and Cooktops))
by crzyred59 10/25/2015 3:05:35 PM(UTC)
Whirlpool Oven Not Heating Properly (Oven Repair (including Ranges and Cooktops))
by Crash55 1/30/2013 2:08:45 PM(UTC)
older ge oven not heating properly (Oven Repair (including Ranges and Cooktops))
by kris23 2/13/2012 7:11:49 PM(UTC)
Issue with oven not heating properly (Oven Repair (including Ranges and Cooktops))
by LOISANN 1/29/2012 5:46:15 AM(UTC)
Admiral oven not heating properly (Oven Repair (including Ranges and Cooktops))
by scotttheis 5/4/2011 11:44:12 AM(UTC)
by KSimmons 2/12/2011 10:31:01 AM(UTC)
by cougar1963 10/29/2010 7:34:18 AM(UTC)
Gas oven not heating properly (Oven Repair (including Ranges and Cooktops))
by wandanyb 3/17/2010 4:47:18 PM(UTC)
by Jinsmom 1/11/2010 3:48:03 PM(UTC)
Kenmore Dual Fuel - OVEN NOT HEATING PROPERLY (Oven Repair (including Ranges and Cooktops))
by chaznsc 11/19/2009 2:09:20 PM(UTC)
by harry foy 12/16/2008 7:36:19 AM(UTC)
kenmore oven not heating properly (Oven Repair (including Ranges and Cooktops))
by harrymckee 8/16/2008 11:49:48 AM(UTC)
by naholter 12/12/2007 7:22:03 AM(UTC)
