chaznsc
#1 Posted : Thursday, November 19, 2009 2:09:20 PM(UTC)
chaznsc
Our Kenmore is not heating properly. It gets warm, but never gets to the optimum temperature for bake or conv bake. It does a clean cycle properly. My dad tested the voltage and it appears to check.
Oven Temp Sensor?
Control Board?
Is this a common occurence? The unit is only a little over a year old.
chaz
chaznsc
#2 Posted : Friday, November 20, 2009 6:12:06 PM(UTC)
chaznsc
Anyone have any ideas?
vanbao
#3 Posted : Tuesday, May 25, 2010 9:37:08 PM(UTC)
vanbao
I have a Kenmore Elite dual fuel slide in range model number 79046629500. For some strange reason, the oven does not turn on even though the control unit does not display any error code. I can set the temperature ro bake or broil like normal but once I hit the start, the oven does not heat.
Is this a high temperature switch issue or could it be the ERC?
Thanks in advance for any suggestions.
