2 Pages<12
abbie
#11 Posted : Tuesday, September 16, 2008 1:48:55 PM(UTC)
abbie
FROMBYU If you check,when the timer call,s for heat the contact is closed.The current goes down the red wire from the timer to the thermal cut off.It leaves there through the red/white down to the operating thermostat.The operating thermostat is closed ,the current passes through the operating stat which is then a red wire,down to the high limit thermostat which is closed, then through the element.That,s 1 side of the 240 volts.The other red wire going to the element is the other side of the 240 coming from the main thermal block. The common is the white/black on the high limit this completes the circuit.
libertyappl
#12 Posted : Tuesday, September 16, 2008 2:10:56 PM(UTC)
libertyappl
Follow the directions (I do recommend getting the correct parts) I'm not sure what those are for, but it's not a Whirlpool!
The "To Harness" is talking about the wire harness.
Nat
frombyu
#13 Posted : Wednesday, September 17, 2008 8:27:00 PM(UTC)
frombyu
Hi Nat,
Ok, so I did just like the part manual said - got a jumper wire, and connected the free coil terminal with the thermal cut off (correct if i am wrong) (where red wire connects)
Now the coil is glowing red all the time, even on Wrinkle Guard setting, when it should be no heat. What did I do wrong?
And also, on the picture with burned area, is that correct part used? it really looks like it should be something with two screws, not one...
libertyappl
#14 Posted : Wednesday, September 17, 2008 8:32:03 PM(UTC)
libertyappl
That's what I was saying before those aren't the correct thermostats for your dryer, it comes in a kit part number 279816 which is both of the thermostats on the element housing.
Nat
libertyappl
#15 Posted : Wednesday, September 17, 2008 8:36:15 PM(UTC)
libertyappl
Look at this post Sublimemaster posted a picture of the parts you should have.
http://forum.appliancepartspros...s-no-heat.html#post34768
Nat
frombyu
#16 Posted : Thursday, September 18, 2008 7:06:42 AM(UTC)
frombyu
Ordered kit 279816, will post more when I install. But what concerns me is the Wrinkle Guard setting - and how the coil was on. I wonder if the coil now is wired to be on every time when the motor runs... But I'll post more after I get the kit.
Thank you.
libertyappl
#17 Posted : Thursday, September 18, 2008 7:41:49 AM(UTC)
libertyappl
It's more likely the incorrect thermostats that were put in. If you need a complete wiring diagram to check all the wires I can probably locate one.
Nat
frombyu
#18 Posted : Tuesday, September 23, 2008 5:19:13 PM(UTC)
frombyu
Hi again... So I installed the kit, and I referred to Replacing 279816 thermal cutoff kit (page 2)post. I still have the problem that on any setting the coil glows... Fluff air, Wrinkle Guard - manual says there is no neat on those settings. I connected black/white wire to jumper wire, so now jumper wire connects the High Limit thermostat terminal #1, and the coil. on the other side of the thermostat there is a red wire now. I tried switching them - no difference.
frombyu
#19 Posted : Tuesday, September 23, 2008 6:05:59 PM(UTC)
frombyu
That's what it looks like now...
frombyu attached the following image(s):
libertyappl
#20 Posted : Tuesday, September 23, 2008 6:11:08 PM(UTC)
libertyappl
Where did you get that part? It is wired correctly. Although that still doesn't look like kit # 279816.....
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
2 Pages<12
