DougSmith
#1 Posted : Monday, September 15, 2008 3:33:25 PM(UTC)
DougSmith
My washer arms do not turn. What could be the problem? Would I be better off getting a new one or trying to fix the one I have?
Doug
libertyappl
#2 Posted : Monday, September 15, 2008 5:10:04 PM(UTC)
libertyappl
Generally, that can be caused by an obstruction wither in the pump or the spray arms themselves.
i tweeked you model number some it's actually KUDM01TJBT0
Nat
macduff
#3 Posted : Tuesday, September 16, 2008 8:25:55 AM(UTC)
macduff
are the arms physically stuck ? i.e. can you manually twirl them around / If so, then you're probably not getting enough water being pumped through them to make them twirl.
Based on my experience, your input filter is clogged. Remove it, clean it, replace it and run the DW with nothing in it.
If the arms still don't move, your pump is maybe clogged or broken ? Remove arms and see if water comes up through the middle.
Good luck.
Macduff
Kitchenaid KUDL03FVSS4 Dishwasher Arms not rotating (Dishwasher Repair)
by ggallant.tx@gmail.com 11/30/2021 10:45:53 AM(UTC)
Dishwasher arms not spinning (Dishwasher Repair)
by Norsedakotan 3/6/2020 7:18:54 PM(UTC)
Maytag Dishwasher Arms not spinning (Dishwasher Repair)
by RichardMoody 7/24/2013 5:45:19 AM(UTC)
Bosch dishwasher arms not circulating (Dishwasher Repair)
by rosey46 10/31/2012 6:52:50 PM(UTC)
Kenmore Dishwasher arms not spinning, reduced force (Dishwasher Repair)
by margiepowers 3/28/2012 11:43:27 AM(UTC)
Dishwasher arms will not spin (Dishwasher Repair)
by cocoreb 6/17/2011 10:11:33 AM(UTC)
dishwasher arms not spinning around (Dishwasher Repair)
by claninga 1/31/2011 10:57:03 AM(UTC)
Dishwasher arms not moving... (Dishwasher Repair)
by SlickTrick903 2/26/2010 9:02:56 AM(UTC)
Frigidaire Dishwasher arms not spinning (Dishwasher Repair)
by castarr 4/3/2009 5:15:18 PM(UTC)
Dishwasher arms wont sping (Dishwasher Repair)
by danapa 7/15/2008 2:02:47 PM(UTC)
