I am getting water in and water is pumping out but nothing in between. Arms are not spinning. Was not sure if it was getting enough water..so i checked the float,seems it was ok. So i added more water to the unit still not washing. It just runs and then pumps water out. Hope yall can lead me in another direction. Thanks.
Run a load (without dishes) using Dishwasher Magic. See if that will clean the jets.
