castarr
#1 Posted : Friday, April 3, 2009 5:15:18 PM(UTC)
castarr
Came home to blinking clocks (power failure) 2 days ago, dishes not clean. Re-ran, still not clean and undesolved soap. This time re-ran, but listened to operation. Started as usual with normal filling noise, pause, then no sound. Opened door to hot water in bottom of dishwasher. Tried other cycle options, including top only wash, still nothing. Cancled cycle and water then pumped out. Any thoughts? Thanks for the help.
TechnicianBrian
#2 Posted : Friday, April 3, 2009 7:13:09 PM(UTC)
TechnicianBrian
Sounds like the pump isn't operating. The best thing to try is remove the kick plate and find the harness and connector to the pump motor. Use a multimeter to verify 120vac when you start a wash cycle. If you have it, then the motor is bad. If you don't, then the control board is a likely area to continue your search. You may must have a loose connector and can fix it quickly.
castarr
#3 Posted : Wednesday, April 8, 2009 11:32:44 AM(UTC)
castarr
Thank you so much for your response! I will have a look at the motor per your instructions and let you know what I find...
TechnicianBrian
#4 Posted : Wednesday, April 8, 2009 2:35:37 PM(UTC)
TechnicianBrian
Sounds good. We will be here.
