Replacement parts for MAYTAG MDE7500AYW DRYER- ELE | AppliancePartsPros.comSee the attachment for a manual.
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.comYou will have to join the site to download the manual but it is free and has lots of info for the appliance DIYer.
Unplug the unit and check the cycling thermostat and the high-limit thermostat with a meter both should be 0 ohms.
Then check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
This may have contributed to the wire burning out.
This may have been your problem and it has now burned out the heating coil or a thermostat.
Now for your original problem.
Just taping up the wire would not have fixed the problem as you have seen.
If you have a dirty or pitted connection it is a resistance. So when current passes through it heat is generated basically that is how a heating coil works.
This causes more pitting etc., which increases the resistance which increases the heat and so on and so on till the connection fails.
You will have to cut back the wire till you get to nice clean copper and the attach a new connector. Be sure to use one rated for high current.
From the sound of it I would also replace the heating relay.
