2 Pages12>
frombyu
#1 Posted : Sunday, September 14, 2008 12:17:16 PM(UTC)
frombyu
Hi Experts!
Hopefully you can help me with this problem: I have a Whirlpool dryer, which is blowing air, but not producing any heat. I took the back off and saw two things that concern me:
1. Soot - I assume from electrical fire or something? The black thing looks OK though, doesn't look like it has any damage - or it was replaced.
2. only one wire is running to the heating coil. Shouldn't there be two wires? I could not find another loose wire anywhere.
Do you guys have suggestions on how to bring the heat back to the dryer? Thermal fuse is OK, I checked for that.
Thank you!
frombyu attached the following image(s):
libertyappl
#2 Posted : Sunday, September 14, 2008 1:12:34 PM(UTC)
libertyappl
Locate the other wire that is supposed to connected to the element.
It either burned off or was bit of or something....... without that wire though you are only going to be air drying...
Nat
frombyu
#3 Posted : Sunday, September 14, 2008 3:33:38 PM(UTC)
frombyu
I was trying to find that wire for a while, bu there is no sign of it anywhere. Is there a diagram I could refer to, or at least get a color, or approximate location of the source?
There are no snapped, cut, or burned loose wires in that area.
The red wire runs from the bottom panel.
libertyappl
#4 Posted : Sunday, September 14, 2008 7:52:35 PM(UTC)
libertyappl
There's a red wire with a white stripe that is missing from your picture. And the wiring is not correct, which is probably where the elecrrical fire came from. I'd say someone has worked on this that wasn't sure what they were doing.
Nat
frombyu
#5 Posted : Monday, September 15, 2008 5:52:54 PM(UTC)
frombyu
Hi Nat,
Thank you for helping me. Here is the diagram, and I think i correctly circled the part in question (coil and thermostat). Why do you think that the missing wire is red with white stripe? That is the only wire that is not color-labeled in that diagram!
And what is the NC code?
Thank you,
Dennis
libertyappl
#6 Posted : Monday, September 15, 2008 6:08:14 PM(UTC)
libertyappl
Theres a jumper wire that's not in the picture (because incorrect parts were installed)it's red w/white stripe. Part number AP3094244 is what is supposed to be there and it has a the jumper wire that's missing from the picture. Sorry I didn't clarify that earlier.
nat
abbie
#7 Posted : Tuesday, September 16, 2008 3:41:40 AM(UTC)
abbie
Frombyu there nothing wrong with the wiring I check the diagram the two heavy red wires carry your 240v to the element the burn,t area may be from the element,shorted to the metal box.Look inside or remove the element and check for any breaks.then start from the first. check you fuses/breakers to make sure there not open.If good,check the operating theremstat to make sure the stat is not open. then check the hi limit thermostat[the one on the can at the bottom] to make sure that not open.....post your findings....
frombyu
#8 Posted : Tuesday, September 16, 2008 8:08:44 AM(UTC)
frombyu
Hi Abbie:
I did a quick check this morning with a battery and a lamp - every fuse ,breaker, and thermostat pass. I will take out the heating element and inspect it closer in the evening.
Abbie, the heating element has only 1 wire connected (the solid Red). There has got to be two, and you say 'the two heavy red wires carry your 240v to the element the burn', I only can see one connected in the first image (PICT0007_post.jpg ), what color is the other wire, and where is it coming from?
libertyappl
#9 Posted : Tuesday, September 16, 2008 8:22:26 AM(UTC)
libertyappl
Here is the wiring instructions for the parts in question. See if this helps. These are the correct parts AP3094244.
Nat
File Attachment(s):
279817.pdf (198kb) downloaded 50 time(s).
frombyu
#10 Posted : Tuesday, September 16, 2008 1:14:12 PM(UTC)
frombyu
Hi Nat,
Ah. Ok - I think it is starting finally make sense. The dryer wasn't heating ever since the wrong part was installed / replaced - because there is no way it could. Seems like the thermostat does have the 3/16" terminal, so I'll need to do the cutting off/crimping the wire, just like it is outlined in the instructions. After I do that, do I install the jumper wire on the thermostat terminal on the left (where red with white stripe) or right (white with balack stripe)? The part manual shows the connector on the thermostat that is closest to the coil connector (that would be left) - is the thermostat wired in correctly? What does "To Harness" mean?
Guest (9)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
2 Pages12>
