I have a GE King Load Capacity washer. After spin cycles the drum has oil streaks in it. It is getting on all the clothes, linen, etc. and ruinning everything. Does anyone know why, what it is and how to fix it? Can it be repaired by us or do we need a professional repair person?
If you're getting oil inside the tub that's never a good sign. Porbably a transmission problem a rather expensive part. But without a model number it's hard to tell. Nat
This doesn't sound good, but I finally figured out that the streaks of grey must indeed be specks of oil during the spin cycle, whipping around and ruining every piece of clothing in the load!! I have a Maytag LAT8204AAL. Any ideas on what I may need to look into repairing???
Personally with the cost of the transmission, seals, probably the clutch assemby, etc. I would recommend just replacing it. Of course we would pull off all good parts, (i.e. timer, motor, etc.) in case someone else needed those parts and couldn't afford new. Nat
So you're telling me to just replace the entire washing machine and not attempt to fix it? I know it is 14-years-old, but it has been perfect until this point!
You can fix it but it is a pain in the rear and costly. replacement maybe cost effective, that's a personal call! Nat
