mcbeach
#1 Posted : Saturday, August 16, 2008 3:08:14 PM(UTC)
mcbeach
I have a GE King Load Capacity washer. After spin cycles the drum has oil streaks in it. It is getting on all the clothes, linen, etc. and ruinning everything. Does anyone know why, what it is and how to fix it? Can it be repaired by us or do we need a professional repair person?
libertyappl
#2 Posted : Saturday, August 16, 2008 6:47:39 PM(UTC)
libertyappl
If you're getting oil inside the tub that's never a good sign. Porbably a transmission problem a rather expensive part. But without a model number it's hard to tell.
Nat
JMA
#3 Posted : Wednesday, September 10, 2008 7:21:22 AM(UTC)
JMA
This doesn't sound good, but I finally figured out that the streaks of grey must indeed be specks of oil during the spin cycle, whipping around and ruining every piece of clothing in the load!! I have a Maytag LAT8204AAL. Any ideas on what I may need to look into repairing???
libertyappl
#4 Posted : Wednesday, September 10, 2008 7:32:28 AM(UTC)
libertyappl
Personally with the cost of the transmission, seals, probably the clutch assemby, etc. I would recommend just replacing it. Of course we would pull off all good parts, (i.e. timer, motor, etc.) in case someone else needed those parts and couldn't afford new.
Nat
JMA
#5 Posted : Wednesday, September 10, 2008 7:36:32 AM(UTC)
JMA
So you're telling me to just replace the entire washing machine and not attempt to fix it? I know it is 14-years-old, but it has been perfect until this point!
libertyappl
#6 Posted : Wednesday, September 10, 2008 9:33:03 AM(UTC)
libertyappl
You can fix it but it is a pain in the rear and costly. replacement maybe cost effective, that's a personal call!
Nat
Guest (7)
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
GE Profile transmission Oil leak (Washer Repair)
by MilwMonstr 11/17/2014 6:39:43 AM(UTC)
Oil leaking in GE Washer (Washer Repair)
by smorberg 9/28/2014 8:48:35 AM(UTC)
Evaporator Coil Leak (Refrigerator & Freezer Repair)
by FrankieVH 10/27/2013 9:23:46 AM(UTC)
GE oil leak (Washer Repair)
by boltonr 7/28/2013 12:57:11 PM(UTC)
Whirlpool gearcase oil leak (Washer Repair)
by veda1 11/19/2012 6:35:45 AM(UTC)
Broken coupler and Gear Oil Leaked (Washer Repair)
by mtnbiker3000 10/16/2012 10:17:12 AM(UTC)
by Barkman 11/9/2011 8:09:20 AM(UTC)
Maytag Washer Oil Leak (Washer Repair)
by rentrop5662 5/15/2011 6:00:42 AM(UTC)
Oil Leaking On Clothes!! (Washer Repair)
by ladyfixer 2/15/2011 2:00:07 PM(UTC)
oil leaked from whirlpool washer on its side (Washer Repair)
by chuckcat 10/18/2010 2:59:50 PM(UTC)
by pelican 9/8/2010 4:02:11 PM(UTC)
oil leaking on floor (Washer Repair)
by gcm 4/27/2010 4:25:45 AM(UTC)
Oil Leaking into the basket (Washer Repair)
by Ruben1977 4/3/2010 4:29:27 PM(UTC)
Kenmore (Whirlpool) Washer slow oil leak (Washer Repair)
by EMcVadon 3/15/2010 8:13:28 PM(UTC)
