Barkman
#1 Posted : Wednesday, November 9, 2011 8:09:20 AM(UTC)
Barkman
With the front panel off I can see a substantial amount of oil (dry) that has splattered on the inside of the cabinet. It seems to be coming from the point where the transmission shaft housing goes into the bottom of the tub.
What parts and tools do I need to fix the leak and what kind of oil do I need to refill the transmission?
applianceman
#2 Posted : Wednesday, November 9, 2011 8:31:41 AM(UTC)
applianceman
Most likely the tub seal is leaking. When this happens (dirty/oily) water will leak down onto the transmission and then when it spins it slings this water everywhere leaving brown spots all over the inside cabinet. To confirm this is the problem, watch the washer during fill and wash and see if water leaks from the center of the tub (where the transmission meets the tub). If so you will need to replace the tub seal. This page will help Maytag Tub Seal Replacement
You will most likely not have to replace the oil in the transmission typically when oil leaks out of the transmission it will leak under the bottom where the belts are. I believe this will be a water leak.
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
GE Profile transmission Oil leak (Washer Repair)
by MilwMonstr 11/17/2014 6:39:43 AM(UTC)
Oil leaking in GE Washer (Washer Repair)
by smorberg 9/28/2014 8:48:35 AM(UTC)
Evaporator Coil Leak (Refrigerator & Freezer Repair)
by FrankieVH 10/27/2013 9:23:46 AM(UTC)
GE oil leak (Washer Repair)
by boltonr 7/28/2013 12:57:11 PM(UTC)
Whirlpool gearcase oil leak (Washer Repair)
by veda1 11/19/2012 6:35:45 AM(UTC)
Broken coupler and Gear Oil Leaked (Washer Repair)
by mtnbiker3000 10/16/2012 10:17:12 AM(UTC)
Maytag Washer Oil Leak (Washer Repair)
by rentrop5662 5/15/2011 6:00:42 AM(UTC)
Oil Leaking On Clothes!! (Washer Repair)
by ladyfixer 2/15/2011 2:00:07 PM(UTC)
oil leaked from whirlpool washer on its side (Washer Repair)
by chuckcat 10/18/2010 2:59:50 PM(UTC)
by pelican 9/8/2010 4:02:11 PM(UTC)
oil leaking on floor (Washer Repair)
by gcm 4/27/2010 4:25:45 AM(UTC)
Oil Leaking into the basket (Washer Repair)
by Ruben1977 4/3/2010 4:29:27 PM(UTC)
Kenmore (Whirlpool) Washer slow oil leak (Washer Repair)
by EMcVadon 3/15/2010 8:13:28 PM(UTC)
oil leaking (Washer Repair)
by gp3002 10/19/2009 8:22:52 AM(UTC)
