wbcarlyle
#1 Posted : Thursday, December 30, 2010 7:47:15 AM(UTC)
wbcarlyle
Heats erratic. 90% of time does not completely dry clothes Occasional ok.
Have done the obvious. Clean lint trap. thoroughly clean trap compartment and exhaust vent to outside. Local vendor advised to change the main thermostat (one on blower housing with 4 wires to it) does not show much improvement. Any suggestions?
WB Carlyle:confused:
Joe / APP Team
#2 Posted : Friday, December 31, 2010 7:17:26 AM(UTC)
Joe / APP Team
WB,
Did you check the vent hood for proper flapper operation ?
Did you check the tumbler seals(front and back for tears or missing areas ?
You may want to check or replace the hi limit thermostat, if all other things have checked OK .
(if the dryer has been cycling on the limit switch, it could be weak).
Also check and make sure the tumbler is rotating properly (48 to 52 RPM).
Good Luck
Happy New Year
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
