Replaced the thermal fuse and the cycle thermostat. checked to make sure gas was working, and can see the ignitor glow red for approx. 10 sec. then goes out. That will happen approx every minute. Just seems it won't light. What is a fix for this problem. Clog? New sensor...ect.
thank-you very much Gene! is there a diagram somewhere i could see where they are located. i couldn't find it on the diagram of parts and numbers or it even listed. Thanks again!
