Discuss
How to open dryer to replace coils on gas valve
 in
Dryer Repair
How to open Roper gas dryer to replace coils on gas valve in a Roper Model RGS7646KQ2 ? The flame
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to open dryer to replace coils on gas valve
  #1 (permalink)
Old 07-08-2009, 10:22 AM
Junior Member
sing611 is on a distinguished road
Default How to open dryer to replace coils on gas valve
Model Number: RGS7646KQ2   Brand: Roper   Age: 1 - 5 years
The flame ignites on start up and fails to ignite after going off, until 10 or 20 minutes later. The ignitor still goes hot for 10 to 15 second in cycle, just no flame. But wait about 20 minutes, the falme can go on again, but cycle of failed ignition continues after it goes out.
Thanks!
Ads By Google
Related Models
Whirlpool RGS7646KQ2
Whirlpool RGS7646KQ3 29" Gas Dryer
Whirlpool RGS7648EN0
Whirlpool RGS7648EN2
Whirlpool RGS7648EN3
Whirlpool RGS7648EQ0
Whirlpool RGS7648EQ2
Whirlpool RGS7648EQ3
Whirlpool RGS7648EW0
Whirlpool RGS7648EW2
Whirlpool RGS7648EW3
Whirlpool RGS7648JQ0
Whirlpool RGS7648JQ1
Whirlpool RGS7648KQ1
Whirlpool RGS7648KQ2
Whirlpool RGS7745PQ0 29" Gas Dryer
Whirlpool RGS7745RQ0 29" Gas Dryer
Whirlpool RGS7745RQ1 29" Gas Dryer
Maytag RGSF3330DW Range - S/c F/s Gas
Maytag RGSF5330DT Range - S/c F/s Gas
Amana RGT350UD Surface Unit - Gas
Amana RGT350UWW Surface Unit - Gas
Amana RGT650UD Surface Unit - Gas
Amana RGT650UWW Surface Unit - Gas
General Electric RGU32N01 Gas range
General Electric RGU32U01 Gas range
General Electric RGU32U02 Gas range
General Electric RGU3501A Gas range
General Electric RGU6501A Gas range
Whirlpool RGX3514PQ0 29" Gas Dryer
Whirlpool RGX3514RQ0 29" Gas Dryer
Whirlpool RGX3514RQ1 29" Gas Dryer
Whirlpool RGX3519PQ0 29" Gas Dryer
Whirlpool RGX3615EW0
Whirlpool RGX4625EN0
Whirlpool RGX4625EW0
Whirlpool RGX4625EW1
Whirlpool RGX4625EW2
Whirlpool RGX4625EW3
Whirlpool RGX4634JQ0
Whirlpool RGX4634KQ1
Whirlpool RGX4634KQ2
Whirlpool RGX4634KQ3 29" Gas Dryer
Whirlpool RGX4635EN0
Whirlpool RGX4635EN1
Whirlpool RGX4635EN2
Whirlpool RGX4635EN3
Whirlpool RGX4635EQ0
Whirlpool RGX4635EQ1
Whirlpool RGX4635EQ2
Whirlpool RGX4635EQ3
Whirlpool RGX4635EW0
Whirlpool RGX4635EW1
Whirlpool RGX4635EW2
Whirlpool RGX4635EW3
Whirlpool RGX5634JQ0
Whirlpool RGX5634JQ1
Whirlpool RGX5634KQ1
Whirlpool RGX5634KQ2
Whirlpool RGX5634KQ3 29" Gas Dryer
Whirlpool RGX5634PQ0 29" Gas Dryer
Whirlpool RGX5635EN0
Whirlpool RGX5635EN1
Whirlpool RGX5635EN2
Whirlpool RGX5635EN3
Whirlpool RGX5635EQ0
Whirlpool RGX5635EQ1
Whirlpool RGX5635EQ2
Whirlpool RGX5635EQ3
Whirlpool RGX5635EW0
Whirlpool RGX5635EW1
Whirlpool RGX5635EW2
Whirlpool RGX5635EW3
Whirlpool RGX5636AL0
Whirlpool RGX5636AL1
Whirlpool RGX5636AL2
Whirlpool RGX5636AW0
Whirlpool RGX5636AW1
Whirlpool RGX5636AW2
Whirlpool RGX6634PQ0 29" Gas Dryer
Whirlpool RGX6634RQ0 29" Gas Dryer
Whirlpool RGX6634RQ1 29" Gas Dryer
Whirlpool RGX6646AL0
Whirlpool RGX6646AL1
Whirlpool RGX6646AL2
Whirlpool RGX6646AL3
Whirlpool RGX6646AQ2
Whirlpool RGX6646AQ3
Whirlpool RGX6646AW0
Whirlpool RGX6646AW1
Whirlpool RGX6646AW2
Whirlpool RGX6646AW3
Whirlpool RH0500RAW00
Whirlpool RH0500RDW00
Whirlpool RH0500REW00
Whirlpool RH0500REW01
Whirlpool RH0500REW02
Whirlpool RH0500RWW00
Whirlpool RH0588RBW00
Whirlpool RH0588REW00
Whirlpool RH0588REW01
Whirlpool RH0588REW02
Whirlpool RH0599RBW00
Whirlpool RH0599REW00
Whirlpool RH0599REW01
Whirlpool RH0599REW02
Whirlpool RH0799RBW00
Whirlpool RH0799REW00
Whirlpool RH0799REW01
Whirlpool RH0799REW06
Jenn-Air RH100 Hood
Whirlpool RH1000RAW00
Whirlpool RH1000RDW00
Whirlpool RH1000REW00
Whirlpool RH1000REW01
Whirlpool RH1000REW05
Whirlpool RH1000REW06
Whirlpool RH1000RYW00
Jenn-Air RH100B Hood
Jenn-Air RH100L Hood
  #2 (permalink)
Old 07-08-2009, 08:23 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the screw on the back of each side end caps of the console. Grab console on both sides. Pull console towards you, lifting the tabs up and out of the console slots. Carefully flip console back. Remove the three screws at the back of the dryer top. Slide top toward you to release top from front clips and rear tabs. Lift top up and off dryer.
Remove the two screws securing the front panel. Lift the front panel up to release it from the retainers on the bottom.
- The coil kit Part number: AP3094251
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RGS7646KQ2 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-08-2009, 09:54 PM
Junior Member
Default
Gene,
Thank you very much for your reply. Wish me luck
-Sing
  #4 (permalink)
Old 07-09-2009, 01:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good luck Sing. Keep us posted.
__________________
  #5 (permalink)
Old 09-05-2009, 04:23 PM
Junior Member
bratch is on a distinguished road
Thumbs up
Quote:
First time user here, found via Google search.
Thanks for the information Gene, it solved my problem.
I had similar symptoms as Sing on a Whirlpool/Roper gas dryer. First I noticed that the clothes were not drying at all, so I opened the back and watched if for a while. When starting from cold I could see a glow in the heater area followed by flames from the ignited gas. After it reached the high temp the flame would shut off. A few minutes later I would see the glow for a few seconds, but there was no gas to ignite. I had excellent air flow through the whole system, so I knew it wasn't being caused by any blockage.
With your instructions and the breakdown diagram I was able to remove the coils and take them with me to the appliance parts store. They tested them and confirmed they were bad. The coil replacement kit (both coils) happened to be one of two featured items on their website this month and cost me $29.88. I've seen them online for less, but this is a local store and they tested the old coils for me. I had also tested them with an Ohm meter and was reading 0 Ohms across all terminals, as if they were shorted.
The only slight difficulty I had was removing the screws without removing the drum. I had it supported with a small, sturdy shoe box and realized a normal size screwdriver wouldn't fit. My short one didn't work either, so I ended up using a small socket wrench with a star-point screwdriver attachment.
I attached a photo of mine. Maybe it will help others when they find this and read about your solution. Oh, I also found about $2 in dimes in the bottom rim area when I removed the front of the dryer.
The wires are not normally on top of the screws. I moved them out of the way so I could get a photo of the burner assembly number in case I needed it. It's very easy to unplug the coils, remove the bracket, and put the coils back. The one with 3 wires goes in front and there are small tabs that line up with the bracket to prevent you from installing them wrong.
  #6 (permalink)
Old 09-05-2009, 04:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you for sharing with us such useful information and picture.
__________________
  #7 (permalink)
Old 06-02-2011, 08:28 AM
Junior Member
rfaulds is on a distinguished road
Smile Thanks!
Thanks to all for their previous postings. Once ordering the replacement kit for the gas coils, the procedure was quite easy and effective for our Maytag MDG9206BWW gas dryer. HEAT! Fast service and a cheap solution for the problem. Thanks again AppliancePartsPros.com !
AP3094251 (279834) Coil kit for dryer gas valve (2 coils, new style) 1 14.47
  #8 (permalink)
Old 06-24-2011, 12:35 PM
Junior Member
rtrickey is on a distinguished road
Default
I assume I need to shut off the gas at the wall before replacing the gas coils. After replacing them, is there a recommended way to test to make sure no gas is leaking?
  #9 (permalink)
Old 06-24-2011, 03:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You do not have to shut off the gas. Just unplug the dryer.
__________________
  #10 (permalink)
Old 06-09-2012, 11:20 PM
Junior Member
NotADryerRepairExpert is on a distinguished road
Default Attention Dryer Expert
Can someone please tell me how and where to get burner coils for a basic looking Whirlpool gas dryer (no model number on front, one dial, one starter button). If you need more info, tell me where to get it. I'll send a gift card to the person who helps me save $100 calling someone to fix it.
Cameron @ myagentgateway.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Gas Dryer Random Heating, replace both coils? troutdog99@aol.com Dryer Repair 0 01-05-2010 10:34 PM
gas valve coils joe209 Dryer Repair 5 10-10-2009 02:39 PM
Who Send Power To Be Energize The Valve Coils juancar92236 Dryer Repair 0 07-17-2009 02:26 PM
Replace coils on gas valve or complete assembly hgrynberg Dryer Repair 1 07-07-2009 04:10 AM
How to gain access to the Gas Valve Coils MonsterBash Dryer Repair 1 02-02-2009 05:05 PM
