pahokee58
#1 Posted : Wednesday, August 27, 2008 11:51:47 AM(UTC)
pahokee58
Timer counts down on all cycles but does not go to the off position, will continue to run until manually turning knob to off position.
Replaced timer switch but is still happening.
#2 Posted : Wednesday, August 27, 2008 5:55:01 PM(UTC)
Originally Posted by: pahokee58 Go to Quoted Post
...Replaced timer switch but is still happening...
When you said "timer switch" you meant the timer or something else?
It does not go to the off position on all cycles or on "auto" only? Did you try the timed cycle?
pahokee58
#3 Posted : Thursday, August 28, 2008 3:50:57 AM(UTC)
pahokee58
It does not shut off on all cycles. Timed cycle or any other setting, it will count down but at the end it continues to run until you turn the knob to the off position manually.
#4 Posted : Thursday, August 28, 2008 4:34:28 PM(UTC)
...When you said "timer switch" you meant the timer or something else?...
I need you to answer this question too.
pahokee58
#5 Posted : Friday, August 29, 2008 3:48:08 AM(UTC)
pahokee58
I replaced the whole control switch, I believe it was Model m460g ? It is the switch that controls the knob for dryer settings. Thanks
#6 Posted : Friday, August 29, 2008 9:15:05 AM(UTC)
What is the part number of the "switch" you replaced?
Need help with dryer not staying lit (Dryer Repair)
by dave50 7/18/2013 4:34:33 PM(UTC)
need help with dryer (Dryer Repair)
by oklabull 6/14/2010 5:15:07 AM(UTC)
by butterfly2boys 4/2/2009 6:10:58 PM(UTC)
Need help with dryer (Dryer Repair)
by Bowhunter1084 9/8/2007 2:04:34 PM(UTC)
