3 Pages123>
Rue
#1 Posted : Wednesday, August 27, 2008 10:02:04 AM(UTC)
Rue
Ok...So...I need help. I have no clue as to what I'm doing and very little money to fix my dryer. It is a gas dryer and the air turns on, but I have no heat. Could someone please help a clueless person?
~Rue~
libertyappl
#2 Posted : Wednesday, August 27, 2008 10:08:23 AM(UTC)
libertyappl
Rue,
For starters do you have or have access to an ohm meter?
Rue
#3 Posted : Wednesday, August 27, 2008 10:12:14 AM(UTC)
Rue
Um...yeah...what the heck is an ohm meter?
~Rue~
libertyappl
#4 Posted : Wednesday, August 27, 2008 10:18:10 AM(UTC)
libertyappl
It can test for electrical current and continuity. It's a meter, a cheap one from the local hardware store will work. (usually around $10).
Rue
#5 Posted : Wednesday, August 27, 2008 10:23:12 AM(UTC)
Rue
Well hey, I learned something new. Hurray for that! :) OKay, once I get this ohm meter, what do I do with it, and is it really necessary?
~Ru~
libertyappl
#6 Posted : Wednesday, August 27, 2008 10:26:53 AM(UTC)
libertyappl
Yes, you need it to test with.
We will start with the basics..... unplug the dryer and make sure you have 120 V of power to that outlet. If so then remove the rear panel on the dryer and do the following
Check ignitor continuity.
Check for gas supply.
Check flame switch continuity, (0 ohms
when cold).
Check gas valves for continuity.
Check thermostat for continuity.
Check for continuity.
Manually close centrifugal switch contacts,
check for continuity, (1M-2M ohms).
[URL="http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=xl1800 spacemaker"][/URL]
Rue
#7 Posted : Wednesday, August 27, 2008 10:35:39 AM(UTC)
Rue
Oh boy,
I hope you have a lot of patience, because I understood maybe a quarter of what you just said. That being said, it's going to take me until the weekend to get the ohm meter. Hopefully you'll be on then. I do thank you for your quick response.
~Rue~
libertyappl
#8 Posted : Wednesday, August 27, 2008 10:43:38 AM(UTC)
libertyappl
I'm on a lot and if my 16 year old can test this stuff you can too! I have 3 teens! I have lots of patients....lol
Rue
#9 Posted : Wednesday, August 27, 2008 10:46:42 AM(UTC)
Rue
Uh-oh, be careful now, because I'm really going to put you to the test. Ah-hahaha!
~Rue~
libertyappl
#10 Posted : Wednesday, August 27, 2008 10:50:49 AM(UTC)
libertyappl
I'm sure we can get your dryer tested, not only do I have 3 teens, but I'm a mom that deals with broken appliances everyday, and home school one of the teens with that has ADHD so....not worried about my patients being tested.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
3 Pages123>
