roscoe0807
#1 Posted : Saturday, December 18, 2010 4:57:27 PM(UTC)
roscoe0807
problem with washer. motor spins, but tub does not spin. replaced belt...same thing. rotated drum by hand and heard a creak and tic. noticed there was a seal or bearing all busted up so i removed all the small pcs. can't seem to figure out what it originally looked like. this seal (or what ever it was) is located on the transmission between the lower gear housing and above the lower bearing housing. it's plastic with steel rounded discs. it is located what seemed to be above the retaining ring that holds the bearing in lower bearing housing. after i removed the fragments, for the hell of it, i started it and it spins just fine now. all setting work fine. no noises or vibrations what so ever. anyone know anything about these transmissions and what the heck was this part that fell apart and prevented the drum from spinning? i have never seen a seal that looks like this with metal rounded plates. these plates are only .25" square and about an 1/8 thick. i think i removed a total of five of these plates. see image attached that shows whrere this seal came out of.
located in the steel housing left of the letter "A" in Appliance. if this is just a seal, how critical is it that it needs to be replaced?
if anyone needs to see pictures of the parts i removed, please let me know. (sorry for the long post)
UserPostedImage
sidfink43
#2 Posted : Monday, December 20, 2010 6:18:56 PM(UTC)
sidfink43
I am not sure what you have, but take a look at this service manual and see if it help you out.
http://frigidaireservicetips.co...thTumbleActionWasher.pdf
Frigidaire Washer Dryer Combo GLET1142CS0 (Washer Repair)
by texashuman 11/16/2020 9:17:08 AM(UTC)
GE Washer Dryer Combo, clothes fell INSIDE how to get to them (Washer Repair)
by stilgarzero 10/27/2019 1:01:06 PM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 1:55:37 PM(UTC)
Frigidaire Washer Dryer Combo Not Working (Washer Repair)
by soshea42 7/10/2016 4:10:09 PM(UTC)
Frigidaire Stackable Washer Dryer Combo center (Washer Repair)
by megabyte5689 1/18/2016 2:56:21 PM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
Washer dryer combo acting up (Washer Repair)
by emshofk 11/26/2015 9:23:32 AM(UTC)
How to remove the tub from GE stackable washer dryer combo (Washer Repair)
by MSJORDAN 6/2/2015 11:42:26 AM(UTC)
Whirlpool Washer Dryer combo (Dryer Repair)
by TommyK 7/6/2014 7:29:56 AM(UTC)
Frigidaire washer dryer combo won't spin or drain (Washer Repair)
by MikeeD 1/24/2014 9:44:02 AM(UTC)
SE1000 washer dryer combo, dryer runs continuously no heat (Dryer Repair)
by mamasanders59 1/5/2014 1:41:28 PM(UTC)
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up (Dryer Repair)
by NVChickey 2/25/2012 10:50:02 PM(UTC)
replacing timer in washer dryer combo (Washer Repair)
by newlyretired 1/15/2012 9:30:36 AM(UTC)
washer dryer combos repair (Washer Repair)
by iblashaun 3/20/2011 8:37:38 PM(UTC)
by Eddie365 10/17/2009 12:35:57 PM(UTC)
