Ed60062
#1 Posted : 15 years ago
Ed60062
The in-door water dispenser on my Kenmore side-by-side has gotten progressively slower. I am thinking it might be corrosion at the point where the copper line attaches to the iron pipe. Or, maybe it is the valve at the dispenser end. I would appreciate any ideas as to what the problem is most likely to be. Thanks.
txrott
#2 Posted : 15 years ago
txrott
Does it have a inline filter?
Ed60062
#3 Posted : 15 years ago
Ed60062
Yes it does have an inline filter and I changed it with no effect on the water flow.
txrott
#4 Posted : 15 years ago
txrott
Sounds like the water valve is going out
Ed60062
#5 Posted : 15 years ago
Ed60062
Thanks, I was hoping maybe just some corrosion blocking the needle valve on the cold water pipe. I hadn't thought of the valve until reading some posts here. I guess checking the connection on the iron pipe is the easiest thing to check first.
txrott
#6 Posted : 15 years ago
txrott
Sometimes that is it...Being a plumber have not had that be the problem very often
Ed60062
#7 Posted : 15 years ago
Ed60062
Thanks, now I just have to figure out where the valve is located and how to get to it.
Qtip
#8 Posted : 15 years ago
Qtip
you will need to pull your fridge out enough to get behind it.. follow the water supply line to where it connects to the fridge. you'll need to remove the cover on the back of the fridge and your water supply line will connect directly to the water valve
Ed60062
#9 Posted : 14 years ago
Ed60062
Problem solved. We had our house totally re-piped and flow is back to normal. Apparently corrosion at the valve was restricting the flow.
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest about a year ago
kenmore water dispenser slow (Refrigerator & Freezer Repair)
by scmb 12 years ago
Water Dispenser Slow to Shut Off (Refrigerator & Freezer Repair)
by chip11 13 years ago
GE Profile Water Dispenser Slow (Refrigerator & Freezer Repair)
by Jesse_Edw 13 years ago
Amana Water Dispenser slow (Refrigerator & Freezer Repair)
by qglasspa 14 years ago
