Hi new here. But have order parts from these guys before.
I'm having issues with my water dispenser. It's slow.
Here's what I've done so far:
1. Checked the water supply. - Flows as it should 2. Changed Filter 3. Used bypass instead of filter 3. Checked for Kinks in back of Fridge 4. Thawed Water Tank 5. Replaced Water Valve 6. I also disconnected the tubing from the door and tried to use the dispenser from just coming out of the top of the fridge. Same still slow.
Not sure what else can be blocking the flow. When i first push it the lever for 1 second its full water flow but after that it is slows.
Any ideas? circuit board maybe? Valve not getting enough power? Or could there be sediment some where?
One more thing I forgot to mention. My ice maker seems to have issues as well. It still makes ice but it makes a clicking noise.
Any help with both of my issues would really help.
Can anyone chime in?
From the post i've been reading here. It seems like i need a new mother board? I'm guessing here!
Can anyone help?
