kelly6825
#1 Posted : Tuesday, December 14, 2010 6:57:52 AM(UTC)
kelly6825
Have read on how to check switches. My push start switch reads 2 ohms which tells me that it is good. I want to check my other switches but not sure were to put the leads. Checking the timer switch there are 15 wires. Need help on were to place leads and what ohms should show. If I understand it right if the meters reads all the way to the left the switch is bad ( side ways eight ) Kelly
magician59
#2 Posted : Tuesday, December 14, 2010 7:51:41 AM(UTC)
magician59
Maybe you can tell us what your machine is (or isn't) doing, that prompts you to check the timer.
kelly6825
#3 Posted : Tuesday, December 14, 2010 8:22:36 AM(UTC)
kelly6825
dryer does not run checked plug and breaker at box all okay then checked
push start switch and read 2 ohms Kelly
kelly6825
#4 Posted : Tuesday, December 14, 2010 9:11:21 AM(UTC)
kelly6825
dryer did not work checked plug and breaker at box all okay. Then checked push start switch had 2 ohms. Was going to check oyher switches what do you suggest Kelly
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
