ajbrenton
#1 Posted : Wednesday, December 1, 2010 8:06:54 AM(UTC)
ajbrenton
The blower on my dryer will not start on its own. If i start the dryer and spin the shaft by hand it starts and runs fine. does the motor just need replaced, is it a low start voltage or internal problem that can be repaired?
#2 Posted : Wednesday, December 1, 2010 4:38:34 PM(UTC)
Looks like the motor start winding has gone bad.
You can check the motor and the capacitor with an ohmmeter.
Disconnect the wire harness connector from the fan motor terminals.
Set the ohmmeter to the R x 1 scale.
Touch the ohmmeter test leads to the motor connector pins with the following wire colors:
a) Violet and blue wires. The meter should indicate between 26 and 38 Ω.
b) Violet and red wires. The meter should indicate between 26 and 38 Ω.
c) Blue and red wires. The meter should indicate between 58 and 72 Ω.
Disconnect the wire connectors from the motor capacitor terminals.
Set the ohmmeter to the R X 10K scale.
Touch the ohmmeter test leads to the motor capacitor terminals. The meter should indicate several ohms, and then gradually return towards infinity.
- The capacitor Part number: AP3777445
ajbrenton
#3 Posted : Thursday, December 2, 2010 2:21:53 PM(UTC)
ajbrenton
does the dryer need to be on or running while testing?
#4 Posted : Friday, December 3, 2010 2:14:53 PM(UTC)
It should be off and unplugged.
Guest (4)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
Belarus Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
