jtorts
#1 Posted: : Monday, November 29, 2010 6:35:40 AM(UTC)
jtorts
How do I change the electonic control pad on this oven.I have changed the oven sensor but did not help.It still shuts off at high temps and reads f3.
magician59
#2 Posted : Monday, November 29, 2010 6:44:47 AM(UTC)
magician59
Here's a parts break down that may help you locate the fasteners that hold the front panel in place. Once you remove it, replacing the clock assembly is "plug and play".Top assembly replacement parts for JENN-AIR SCG20200B RANGE- S/C S/I GAS | AppliancePartsPros.com
Part number: AP4009001
main contol panel (Refrigerator & Freezer Repair)
by raisinnn 7/13/2015 11:08:19 AM(UTC)
Control Flashing PF after install of new Contol Panel (Oven Repair (including Ranges and Cooktops))
by April39073 7/27/2012 12:19:31 PM(UTC)
wanted:contol panel schematic (Oven Repair (including Ranges and Cooktops))
by eroc1313 12/7/2011 2:12:10 PM(UTC)
Oven getting F1-1 error - need to make sure I get proper contol panel (Oven Repair (including Ranges and Cooktops))
by beemie96 9/1/2011 9:59:01 AM(UTC)
Double Oven Contol Panel Inoperative (Oven Repair (including Ranges and Cooktops))
by CATBird1 10/24/2010 4:32:25 PM(UTC)
Contol Panel locked (Dryer Repair)
by lbelton1 10/2/2010 6:07:34 AM(UTC)
Kenmore gas range contol panel problem (Oven Repair (including Ranges and Cooktops))
by scba911 4/5/2010 7:51:28 AM(UTC)
Calypso Dryer Contol Panel Problem (Dryer Repair)
by Tony1057 8/3/2009 3:33:38 PM(UTC)
Dishwasher no contol panel power (Dishwasher Repair)
by wxq4 3/4/2009 6:22:33 PM(UTC)
Contol panel (Oven Repair (including Ranges and Cooktops))
by wtuck462 9/25/2008 8:56:17 AM(UTC)
